Gear Ratio Converter
br3n
You might be thinking of the one I made a while ago and uploaded. But now Imageshacks being cack, so I'm re-uploading it to photobucket as I speak, shall edit when done. (Y)
You might be thinking of the one I made a while ago and uploaded. But now Imageshacks being cack, so I'm re-uploading it to photobucket as I speak. Hear you go, if this is what you're after:
you dont need a convertor or anything confusing like that at all Bren!
just divide the front cog by the rear......
22:19 = 1.158
22:18 = 1.22
22:17 = 1.29
20:18 = 1.11
20:17 = 1.17
20:16 = 1.25
18:15 = 1.20
18:16 = 1.125
16:14 = 1.14
thats all the most common gears i can think of, and its far easier than using a silly convertor!
personally, from those, i think the best are 22:19, 20:17, 18:16, and 16:14. they all seem about right.
22:19 = 1.158
22:18 = 1.22
22:17 = 1.29
20:18 = 1.11
20:17 = 1.17
20:16 = 1.25
18:15 = 1.20
18:16 = 1.125
16:14 = 1.14
Dont know if you looked at the "silly" converter I posted Prawnie but it has a very useful feature that the above doesnt.
Tells you how far the bike will travel for 1 pedal rev and also takes into acount two other important factors, wheel size and crank length.
Useful for 24 and 20's
But each to their own :P
just go 18/17 thats the best
no it isnt.
gear ratio is all down to personal preference really, although, that said, MOST people will find 18:17 FAR too easy..... i rode porters ashton with 18:17 and it was stupid..... so light and flicky for gaps, but SO spinny for anything with speed.
chris: didnt look at your sheldon convertor, as ive only ever needed my way :P
ive only ever run 170mm cranks, and a 26'' wheel, so i only ever need to work out equivalent ratios for my otherwise unchanged bike, as is probably the case for most people.
really wanting to try 18:16 soon with a heatsink bash, but dont know if itll be a TINY bit too easy, i know 18:15 will be too hard
22:19 = 1.158
22:18 = 1.22
22:17 = 1.29
20:18 = 1.11
20:17 = 1.17
20:16 = 1.25
18:15 = 1.20
18:16 = 1.125
16:14 = 1.14
thats how i do it
