Ducko Posted April 16, 2007 Report Share Posted April 16, 2007 hi, im thinking of running rear disk soon on my mod bike,im going to build my king bmx hub into an iso hubshell and run a disk.i was wondering if anyone uses a disk on a king and how well it does asin i dont want to buy all the new shell etc and get it built then have it snap.cheers guys Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted April 16, 2007 Report Share Posted April 16, 2007 hahahaha dd has tempted you craigall i know is you can get them from aspire,but he gets a normal shell and gets it changed Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 16, 2007 Report Share Posted April 16, 2007 I did, worked fine. It's just that the disc mount is too close to the frame. If you're using a 110mm frame you'll need to machine down the hub or if you don't want to do that to such expensive equipment, bodge an adaptor. If you've got a 116mm frame then you just need to put both chain tugs on the non-drive side. Quote Link to comment Share on other sites More sharing options...
Ducko Posted April 16, 2007 Author Report Share Posted April 16, 2007 do you know how much your suposed to machine off, cos surly that effects the strength.cheers Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 16, 2007 Report Share Posted April 16, 2007 Talk to Oakley, he had it done to his Quote Link to comment Share on other sites More sharing options...
