04 Or 05 Maggie Levers
Grant H
I personally prefer the 05 lever. Feels a lot more solid (But then again I haven't owned a new 04 lever). Also there's a lot of linkages inside the 04 lever from the TPA to the actual piston (more to go wrong), maybe weighs more too.
But saying that, the 04 lever seems a lot more rugged (I've just snapped an 05 lever just by tightening it to the bars too much!).
So all in all they're pretty much the same, just personal preference. I read somewhere the 05 lever gives you more mechanical advantage?
Yer the way to solve that is if the threads do snap then just stick a longer bolt in so it will grab the left over thread but make sure you don't overtighten the longer bolt or you will have to buy a whole new lever and they quite expensive for the 05 ones.
