Z o o !! Posted April 14, 2007 Report Share Posted April 14, 2007 Does Anyone Use The Adamant Brake Pads If So Are mThey Any Good ? Quote Link to comment Share on other sites More sharing options...
Mike W Posted April 14, 2007 Report Share Posted April 14, 2007 As with all brake pads it depends what setup you have if you have a grind go for something like rock pads blue, if you use tar the brake pad really wont make much difference as the pad hits the tar rather than the rim.mike W Quote Link to comment Share on other sites More sharing options...
Adilogy Posted April 14, 2007 Report Share Posted April 14, 2007 I have 2 pair but yet to try. But it should be about the same as zoo! brakepads. Quote Link to comment Share on other sites More sharing options...
Boswell Posted April 14, 2007 Report Share Posted April 14, 2007 the pad hits the tar rather than the rim.mike WOf course the break pad still touches the rim it just increases friction. Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted April 14, 2007 Report Share Posted April 14, 2007 I use zoo! brake pads which are of a similar compound, the adamants are harder so it increases wear life, this would make them more suitable for a light grind compared with the zoo's. I would warn about the backings which wobble alot compared to any other pads I've seen. Quote Link to comment Share on other sites More sharing options...
