PaRtZ Posted April 12, 2007 Report Share Posted April 12, 2007 Its been naggine me since the moment I knew what it was: Whats brackety about it? Don't understand the logic sometimes...... Quote Link to comment Share on other sites More sharing options...
Broomer Posted April 12, 2007 Report Share Posted April 12, 2007 its a bracket which fixes something to the frame, and its at the bottom? Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted April 12, 2007 Author Report Share Posted April 12, 2007 THATS a bracketits like calling a steerer tube a front bracket Quote Link to comment Share on other sites More sharing options...
spmcfadden Posted April 12, 2007 Report Share Posted April 12, 2007 A bracket fixes two things together (like the above photo) so fixing the cranks to the axle it’s like a bracket.A headset being a set of separate bearings and cups at the head seems more obviously named. Quote Link to comment Share on other sites More sharing options...
Wrayvon Posted April 13, 2007 Report Share Posted April 13, 2007 A bracket fixes two things together (like the above photo) so fixing the cranks to the axle it's like a bracket.A headset being a set of separate bearings and cups at the head seems more obviously named.I assume this reasoning is correct Quote Link to comment Share on other sites More sharing options...
eskimo Posted April 13, 2007 Report Share Posted April 13, 2007 But on a trials bike if it's not a seat tube what is it? Quote Link to comment Share on other sites More sharing options...
spmcfadden Posted April 13, 2007 Report Share Posted April 13, 2007 Always used to have the seat there so has always been called a seat tube.If you look sideways at a frame it is like a quadrilateral - top tube, down tube, chain stay and seat stay, then without the seat tube the frame would flex a lot. The seat tube stops that happening, so you could call the seat tube a bracing member, like in steel buildings.If you had a square shape made of steel beams and pushed on one corner then it would deform, but putting in diagonal beams connecting the opposite corners (so is a square with a cross in the middle) then that stops it happening. Like in a frame the seat tube stops the top half of the bike squashing down.I vote for just calling it a seat tube! Quote Link to comment Share on other sites More sharing options...
gilly Posted April 13, 2007 Report Share Posted April 13, 2007 I think everyone should just have trials bikes with seats then the issue would never come up! (and people would be more comfy) Quote Link to comment Share on other sites More sharing options...
