King C Posted April 12, 2007 Report Share Posted April 12, 2007 Ok my mate has an Echo Team which he wants to spray but doesn't really know how to prepare it. Will sanding it down to the bare metal be necessary or just sanding it to roughen up the surface be enough.Also will the same apply with brushed fork as I want to do mine aswell.CheersKing and co. Quote Link to comment Share on other sites More sharing options...
br3n Posted April 12, 2007 Report Share Posted April 12, 2007 the finnish is electronically added to the metal, I cant remember the exact process but basically the way it sits onto the metal it should be fine to just paint onto. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted April 12, 2007 Report Share Posted April 12, 2007 sand it, if you just spray over it its flakes off.. sand it Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 12, 2007 Report Share Posted April 12, 2007 (edited) Roughening up the surface should do.edit: you need to remove any paint/laquer beforehand of course Edited April 12, 2007 by Inur Quote Link to comment Share on other sites More sharing options...
Guest Posted April 12, 2007 Report Share Posted April 12, 2007 the finnish is electronically added to the metal, I cant remember the exact process but basically the way it sits onto the metal it should be fine to just paint onto.This happens with some things where the paint is in the atmosphere is charged, and when electronic current is put through the object the paint is attrected to it, or something along those lines.If your painting a frame yourself you wont have access to that sort of stuff, and it only works when paint is going onto the bare metal, so in this case he will need to at least, roughen up the surface, to give the new paint something to stick to. Quote Link to comment Share on other sites More sharing options...
