Lara Croft
RR_Trials
im playing the old old playstation one game lara croft and im on the level where you get to explore her house and i remembered the part about the maze and when you get to the middle there is a button you can press and it zooms to a video clip of underneath the stairs in a house and a door is opening. When you run back to the house there is no door does anybody know what you have to do?
Also my girlfriend seems to think that you can obtain a quadbike from the maze, is she just speaking out of her ass?
Cheers for the help, Rorz!
Isnt the door under the stairs? Im sure i found it, it was just never open. Never found the secret bit. Good game though.
I belive that is correct, as for the door and stuff, I'm not sure.
I odn't think you get it out of the maze, rather than from an area accessed via the maze.
Tomb Raider 3 right??
To get to the really cool quad racing track in Lara's house do the following:
1 - Go up to the attic and push in the block there two times.
2 - Go down out of the attic and round to the library.
3 - Along the bookcase at your right look for a book that is sticking out.
4 - Go up to this book and press action to turn it around.
5 - The fire in the fireplace will go out. Climb up the fireplace (do this quickly because the fire comes back on after a while).
6 - Follow the path to the secret room with the lever.
7 - Climb up the ledge and push the block in once so that it is pressed in against the wall. There should now be a path from the secret room into the attic.
8 - Pull the lever and very quickly run down to the direction of the gym but don't enter it - go into the secret door that has just opened. (This may take a few tries as the door doesn't stay open for long).
9 - Follow the path until you get to the large aquarium. Push the block there until it's directly under the hole in the ceiling.
10 - Climb up onto the block, into the passageway in the roof and into the water.
11 - Swim all the way around to the other side of the aquarium, pick up the key and climb back out.
12 - Go back the way you came and go out of the house.
13 - Go over to the grassy wall where there is a gate and a keyhole and open it using the key.
14 - You will now find yourself in the quad racing track! This is very cool!
n.b You might want to lock the butler in the freezer before you start to prevent him getting in your way when racing down to the secret door by the gym.
Edited by ManxTrialSpaz
i think you just gotta be super fast or it shuts again.
i remember on tomb raider 1, you had to press a button in the loft then pretty much launch yourself over the banister and leg it to get through the secret door in time.
and yes, if you are playing tomb raider 3, there is a gate outside in some bushes (might be a maze can't remember) and there is a quad though there, with an entire race track/assault course thing.
i only used to play tomb raider for the house parts, i loved locking the butler in the fridge and stuff. "lets do some tumbling" hell yeah!!!
Oh god. You have made me smile with some memories. Christ. Tomb Raider 1. Golly gosh. Me and my cousin sat on that game for 2 days straight when we were about 11. It was rock solid back then. In 2 days we had only just done the first level. Oh the fun it was. I wish i could go back and do it again.
Im not quite sure about the bit your on about though. Was along time ago now. But im sure you just have to be super quick. I think i manage to do it.
Good luck dude.
Danny.
Which blocks in the attic?
in the master bedroom (it seems) there is a switch to the left of the bed, when you try to click on it lara croft replies no.. what is it for?
erm, i think it maybe turns off the fire so you can go in and get something.
i can't remember which game exactly, i think it was tomb raider 3 but on one of them you had to hit a switch in the attic, then run downstairs and get through a secret door in the hall way,
then inside there was like antiques and stuff, you do something else and get into a huge fish tank with piranha's in....you have to be quick so you don't get eaten but you then dive down and grab a key, then come back out.
then that key can be used to unlock a gate outside where you can then ride the quad around the track and do time attacks and stuff.
if she says 'no' on a lock then it means you need to find a key.
come to think of it, me and my mates would roll with laughter for literally minutes whenever she said 'no', it was a running joke in real life with one of my best mates, just because of the super posh way she says it....kinda like super nanny.
Yeah, I remember this! You just have to run really really fast and make sure you know exactly which way to go in the maze. There's no margin for error at all.
Ahh memories..
I had this game on Sega Saturn when I was about 8? B)
Me and my dad got stuck on the level where you need the cogs to get past some waterful bit?
The level is called "The Lost Valley". It has a T-rex in it. You have to collect all three cogs to drain the water and then you climb up the ledge and go through the door to progress to the next level.
Danny.
Danny.
Yeeaaahhh.. that's the one.
We got to the T-rex..don't remeber the rest.
Don't remember all the details like you...loser. :P
Or the cheaters way of getting to the quad track is to go to the front door(this only works on pc) and stand in the porch and face to the right slightly close to the wall, then start jumping untill u suddenly get raised up to the roof, then run around to the roof and carefull the line yourselt up with the hedge for the quad track then run off the roof dont jump or you will die a horrible painful death and lara will be screaming like b*atch and die. I dont cheat on games a swear
Going back to my girlfriends house tonight so i will give it a go again. Just one question though. Which blocks in the attic?
Infact would someone be so kind as to explain how to get the quad track on the PS2 for me again or just tell me what block i have to push in, in the attack as i can't do anything else without knowing this.
Cheers for the help.
