Matthew_Gibson Posted April 11, 2007 Report Share Posted April 11, 2007 Right, I was trying to make my bike run tensioner less by putting a half link in, thing is the chain had a bit too much sag in it. So I put my old tensioner back on. all is well! Was out riding and after about 1 hour of riding it all suddenly goes stiff on me. Not that much a cant ride, but a little bit stiffer. like the chain is too tight, But the chain is fine. I pedal and it feel like I have a harder gear ratio. Kind of odd. What could the problem be? Inside the hub? I'll be putting my Rohloff back on with KHE chain and see if that sorts it out. Can anyone help me out? Thanks for your time! Quote Link to comment Share on other sites More sharing options...
dave85 Posted April 11, 2007 Report Share Posted April 11, 2007 Take the chain off the sprockets, try moving the cranks, pedals, wheel and freehub independantly of each other. Should give you some idea what's up. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted April 11, 2007 Report Share Posted April 11, 2007 mine has don ethis befor.. took it paart gave it all a good clean.. also just unclipping the wheel helped loads, sort of got stuck in a position where it was putting alot of pressure on the hub..try it Quote Link to comment Share on other sites More sharing options...
