Truvativ Gigapipe Dh "bb"
N Roach
Yes. The axle are strong, but the bearing-seals could be better.
They tend to last well if you keep them away from any kind of dirt or water atall.
Oh yeah, it takes the one with the prongs around the outside, not the splines on the inside. Like, the one shimano BB's DONT take.
Edited by Dont you Just Hate it When...
I've got one, been great but I've only had it for a few months so not much to judge from. It takes an XTR tool, but it might need machining. I got a standard tool from Tarty and it wouldn't fit over the drive-side spacer, luckily Tarty were very helpful and swapped it for an especially machined out tool.
Will the Echo Bottom bracket be better as it will get wet and dirt?
Echo Bottom bracket: http://www.tartybikes.co.uk/product.php?id=2123
Cheers
nafan
I don't have any experience with the echo's, but if I was spending that much I would get the SKF instead, if you can wait for them to restock (or find somewhere else that sells them)
http://www.tartybikes.co.uk/product.php?id=2027
Gigapipes are still very good though :)
yep ive got the truvative bb and tartys tool to fir it. Ive run it for a month or so no and it's seems pretty nice, smooth and still working (touch wood) so i'm happy. Tensile will be bringin out a bb soon, going into testing over the next couple of weeks. Might be worth the wait?? cheers-Hugh
I had a gigapipe on my zip. Maybe caleb will take a picture of the 'effort' used to get the bugger in! It wouldn't fit in the zona BB shell for some reason until I got molegrips + extension bars on the go :)
But once it was in I had no troubles at all. No wear, no bendage, no creaking. Bearings are a little still, making crankflips very hard indeed but hey if tgs floats your boat, your all good (Y)
Been using the Gigapipe for a year for cross country and downhill. It's been completely immersed in water multiple times, been muddy and done loads of street heavy landings with no problems at all.
Park Tool £12.99
http://www.chainreactioncycles.com/Models.aspx?ModelID=17702
XTR £8
http://www.tartybikes.co.uk/product.php?id=142
If the XTR fits then save the money!
