onzat-comp Posted April 7, 2007 Report Share Posted April 7, 2007 HiI took my gu hub out the other night to clean it all went well but, i thought my spacer for the drive side was a little loose so i tryed to squash it together and it went a little egg shaped. I got it the best i could and it goes on and off but is a little stiff, Anyway i then put my back wheel in and set up the cams and tention but when i tighten the back wheel the cranks go really stiff. I normally set my tention to this level but it never goes that stiff. i don't know if a bearing has seized but i can order those, i just need to know if tarty or select or any other company can supply spacer. the spacer is the same in GU ,ZOO and ECHO freehubs.However i have a freewheel and a freehub at the moment but have money for a fixed cog could that be the problem.Thanks in advance for any help RickPS: This is what the spacer looks like in case anyone dosen't know. Sorry for the bad picture its all i could get. :$ Quote Link to comment Share on other sites More sharing options...
sex_on_wheels Posted April 7, 2007 Report Share Posted April 7, 2007 HiI took my gu hub out the other night to clean it all went well but, i thought my spacer for the drive side was a little loose so i tryed to squash it together and it went a little egg shaped. I got it the best i could and it goes on and off but is a little stiff, Anyway i then put my back wheel in and set up the cams and tention but when i tighten the back wheel the cranks go really stiff. I normally set my tention to this level but it never goes that stiff. i don't know if a bearing has seized but i can order those, i just need to know if tarty or select or any other company can supply spacer. the spacer is the same in GU ,ZOO and ECHO freehubs.However i have a freewheel and a freehub at the moment but have money for a fixed cog could that be the problem.Thanks in advance for any help RickPS: This is what the spacer looks like in case anyone dosen't know. Sorry for the bad picture its all i could get. :$ you are running them both on the bike!?! Quote Link to comment Share on other sites More sharing options...
onzat-comp Posted April 7, 2007 Author Report Share Posted April 7, 2007 Ye bit supid i no but im on a budget and was waiting for money of my mum for a fixed cog and iv'e got i now and am ordering a cog tomorrow i think Quote Link to comment Share on other sites More sharing options...
basher Posted April 7, 2007 Report Share Posted April 7, 2007 Well the fact your runing a freehub and freewheel won't make anything stiff just make it feel like theres less pickups. Dont no much about the deng hubs and the insides and the spacers used ect so cant help you there. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted April 8, 2007 Report Share Posted April 8, 2007 (edited) ahhhhhhhhh so your the rick that was at phills house was waiting in wath for 45mins to go riding! naughty!anyways like i said to phill, the washer or spacer your explaing could be the problem. With you forcing it in could be forcing it to far into the hub, when the hub and cams are conpressed against the frame with tightening the bolts causeing it to sorta lock up?just a teory as ive never had 1 apart and have a good look :< Edited April 8, 2007 by Echo_Scotty Quote Link to comment Share on other sites More sharing options...
onzat-comp Posted April 9, 2007 Author Report Share Posted April 9, 2007 well i have the new plaz cog on order and two new bearings on too because one has seised up. as for the spacer i have got a new one thanks everyone sos for making you wait scotty rick Quote Link to comment Share on other sites More sharing options...
