downhill_rob2@hotmail.com Posted April 7, 2007 Report Share Posted April 7, 2007 Hi there peeps,Well, i think i might change my colour scheme on my on my bike, but i dont want to fork out hundreds of pounds buying new parts... so i was wondering... does nitromorse work on anodized parts?I.E, zoo! bars, Echo CNC cranks, Echo 2007 rims? oh and i have a chrome stem i want stripped, will it also do this? Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 7, 2007 Report Share Posted April 7, 2007 It's a paint stripper, it won't remove anodizing. I remember Ben Travis writing something about caustic soda working? Quote Link to comment Share on other sites More sharing options...
zoo Posted April 7, 2007 Report Share Posted April 7, 2007 Caustic soda will remove anodizing,just be careful with the stuff. Quote Link to comment Share on other sites More sharing options...
Davetrials Posted April 7, 2007 Report Share Posted April 7, 2007 is my zona panited? Quote Link to comment Share on other sites More sharing options...
Si-man Posted April 7, 2007 Report Share Posted April 7, 2007 Caustic soda will remove anodizing,just be careful with the stuff.It melts skin nicely. Quote Link to comment Share on other sites More sharing options...
Deonn h Posted April 7, 2007 Report Share Posted April 7, 2007 yeh i used caustic soda to strip cranks , just be carful.After you do it spray it with water till all the stuff is off then ul have to rub it with wire wool or summert to get it siver. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted April 7, 2007 Author Report Share Posted April 7, 2007 Iv heard bad things about acoustic soda, it isnt menna be good for the metal if im correct?Anyways, its only bars, cranks, rim and stem i want stripped, so it shouldnt be too much of a fuss really...Oh and maybe hub, not too sure about that, might just spray ontop of the anodised? Quote Link to comment Share on other sites More sharing options...
Davetrials Posted April 7, 2007 Report Share Posted April 7, 2007 ali c did his hope pro 2 with caustic soda, and it looks like a gem. Quote Link to comment Share on other sites More sharing options...
Deonn h Posted April 7, 2007 Report Share Posted April 7, 2007 ali c did his hope pro 2 with caustic soda, and it looks like a gem.I would have thought that would have damaged the internals but obviously not. cool Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 7, 2007 Report Share Posted April 7, 2007 I would have thought that would have damaged the internals but obviously not. coolIm sure he dismantled it Quote Link to comment Share on other sites More sharing options...
Si-man Posted April 7, 2007 Report Share Posted April 7, 2007 I would have thought that would have damaged the internals but obviously not. coolOnly eats aluminium, won't do much to steel.It's also good for cleaning alloy wheels on cars, just dilute it right lol. Quote Link to comment Share on other sites More sharing options...
moza Posted April 7, 2007 Report Share Posted April 7, 2007 he stripped it before he put caustic soda anywhere near it lolmoza Quote Link to comment Share on other sites More sharing options...
Tomm Posted April 7, 2007 Report Share Posted April 7, 2007 might just spray ontop of the anodised?Yeah just do that. You don't need to take the anodising off if you're planning on spraying it, just rough it up a bit with some wet&dry. Quote Link to comment Share on other sites More sharing options...
matt rushton Posted April 7, 2007 Report Share Posted April 7, 2007 Nitromorse does take off anadising.Matt Rushton Quote Link to comment Share on other sites More sharing options...
Si-man Posted April 7, 2007 Report Share Posted April 7, 2007 Nitromorse does take off anadising.Matt RushtonHow?Considering it isnt just stuck on the surface like paint? Quote Link to comment Share on other sites More sharing options...
joe b Posted April 8, 2007 Report Share Posted April 8, 2007 No, it won't. Get some Caustic Soda from 'B & Q' and folow the instructions that are on the back of the container for mixing it in water. Then get two rags - one to wipe on the caustic soda and another to wipe it off. When i did my ronnie rim i concentrated on it a section at a time. Dab on the caustic soda, making sure you cover all of it, leave it for about 5 minutes to work then wipe it off with a dry rag. It should just turn silver .It's quite easy just a little bit time consuming but don't rush it .Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
Si-man Posted April 8, 2007 Report Share Posted April 8, 2007 Once its done though, does anyone use anything to protect the aluminium from going white and losing the finish your originally after? Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 8, 2007 Report Share Posted April 8, 2007 It's really hard to laquer a polished surface, everything just chips off. So I guess the laquer would need to be baked or something? Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) if you're going to use caustic soda on handlebars be careful because:1.it will also very slightly weaken the bars, espscially if you use to much and take off too much metal aswell as the anodising!2.it will very slightly reduce the diemeter of where the stem clamps the bars and it may eat through the textured part which the stem grips on causing the bars to slip more readilyOnce its done though, does anyone use anything to protect the aluminium from going white and losing the finish your originally after?pollish it with autosol, then when it starts visibly be oxidising pollish it again...repeat this a few times the it seems to retain it's shine better!i also use a little bit of car wax on my echo frame...i polished it with autosol, it came up really shiny so then i waxed it and if you keep it waxed it stays shiny Edited April 9, 2007 by samdoman Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted April 9, 2007 Report Share Posted April 9, 2007 don't do it to the splines on your cranks, will make them too big for your bb splines, think of a small cock in a large pussy... Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted April 9, 2007 Report Share Posted April 9, 2007 is my zona panited?Nitromorse will work on your frame Dave.Danny. Quote Link to comment Share on other sites More sharing options...
squince Posted April 9, 2007 Report Share Posted April 9, 2007 Ive caustin soda'd everything, never had any problems. Quote Link to comment Share on other sites More sharing options...
deanie-b Posted April 9, 2007 Report Share Posted April 9, 2007 don't do it to the splines on your cranks, will make them too big for your bb splines, think of a small cock in a large pussy...Tragic Quote Link to comment Share on other sites More sharing options...
Deonn h Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) don't do it to the splines on your cranks, will make them too big for your bb splinesIt actually dosent though... as ive done it. Edited April 9, 2007 by Deonn h Quote Link to comment Share on other sites More sharing options...
Broomer Posted April 9, 2007 Report Share Posted April 9, 2007 It actually dosent though... as ive done it. haha small cock. Quote Link to comment Share on other sites More sharing options...
