Phil H Posted April 5, 2007 Report Share Posted April 5, 2007 I'm doing some woodwork for GCSE: a childrens trike.-I sanded all the wood down-Applied one layer of sandant sealer- Smoothed down with wet and dry paper- Applied a second layer of sandant sealerI am now gonig to smooth that down with wet and dry paper however after, once ive applied the yacht varnish do I then again sand that down with wet & dry paper to fully finish the product?Cheers. Phil Quote Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2007 Report Share Posted April 5, 2007 When I've done it on our boat, I tend to sand it right down to the wood, getting the nice natural colours showing, then we usualy put at least 6 coats of varnish on it, lightly sanding between each one. Our barnishing last's for years because of this and we only need to rub it down and put 2 or 3 coats on each year once you do it right first time. Quote Link to comment Share on other sites More sharing options...
Phil H Posted April 5, 2007 Author Report Share Posted April 5, 2007 When I've done it on our boat, I tend to sand it right down to the wood, getting the nice natural colours showing, then we usualy put at least 6 coats of varnish on it, lightly sanding between each one. Our barnishing last's for years because of this and we only need to rub it down and put 2 or 3 coats on each year once you do it right first time.Ok cheers for the information. What I mainly need to know is does the process finish with a varnishing or finish with a light rubbing down? Phil Quote Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2007 Report Share Posted April 5, 2007 finish by varnishing.Sand it down just a little between coat's so the new stuff has something to stick to and then make sure the last coat you do is well done because it the one which counts. make sure to let it fully dry out aswell. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 6, 2007 Report Share Posted April 6, 2007 Bah, Danish Oil is where its at. Quote Link to comment Share on other sites More sharing options...
