Cha$e Posted April 5, 2007 Report Share Posted April 5, 2007 As the title suggests i need to know where the fluid on HS 11's goes for a friend asap. We need to shorten his hoses but cant do it until we know where to replenish the fluid and bleed them. Thanks in advance.Cha$e Quote Link to comment Share on other sites More sharing options...
Joe Aston Posted April 5, 2007 Report Share Posted April 5, 2007 If you look on the break cylinder on the break with only one hose going into it there will be a bolt undue that. Also there is a bolt in the lever body. Fluid goes in those to places. Thats a pants description. I wouldn't bother with fluid water gives a much nicer feel.http://www.trials-forum.co.uk/forum/index....showtopic=65710 Quote Link to comment Share on other sites More sharing options...
Cha$e Posted April 5, 2007 Author Report Share Posted April 5, 2007 cheers mate also is there any specific steps we should use to shorten the hoses? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted April 5, 2007 Report Share Posted April 5, 2007 Quote Link to comment Share on other sites More sharing options...
Cha$e Posted April 5, 2007 Author Report Share Posted April 5, 2007 ash-kennard said: well that seemed obvious but is there any special implements we need to use? Quote Link to comment Share on other sites More sharing options...
abe Posted April 5, 2007 Report Share Posted April 5, 2007 make sure its a clean cut, and that no plastic covers the hole, or your breaking will feel horrid. Quote Link to comment Share on other sites More sharing options...
Cha$e Posted April 5, 2007 Author Report Share Posted April 5, 2007 do we shorten from the cylinder end or the lever end? Quote Link to comment Share on other sites More sharing options...
Mike W Posted April 5, 2007 Report Share Posted April 5, 2007 If it doesnt desperately need doing i really wouldnt bother doing it, shortining hose is the most anoying thing i have done mike W Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted April 5, 2007 Report Share Posted April 5, 2007 Just get a Stanley knife and give it a good clean cut.I tried shortening my Hs33's without getting air into the system, as it is apparently possible, but it needed a rebleed.Just take the brake down to a bike shop and they'll do it for a small charge if you dont want to bodge it yourself. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted April 5, 2007 Report Share Posted April 5, 2007 Don't forget that you'd need a new olive for when you put it all back on... Quote Link to comment Share on other sites More sharing options...
JackF Posted April 5, 2007 Report Share Posted April 5, 2007 i have just done this with my new hs33's and so :firstly, undo the hosing on the lever and hold it over a something to catch the fluid,next, undo the bolt on the slave cylinder and all the oil with flow out as the air takes up the spacenow, cut the hosingthen, reattach the hosing to the levernow, undo the bleed nipple on the lever ( hole next to where the hosing go into the lever)next, push the fluid into the cylinder end until the oil or (water) starts to come out of the leverthen, put the bleed nipple back in and finally screw the bolt back in the cylinder trying not to get air in the system and then go out and ride( whilst doing all that make sure your oil does not spill on the brake pads)hope this helpsjack Quote Link to comment Share on other sites More sharing options...
mrturner08 Posted April 5, 2007 Report Share Posted April 5, 2007 JackF said: i have just done this with my new hs33's and so :firstly, undo the hosing on the lever and hold it over a something to catch the fluid,next, undo the bolt on the slave cylinder and all the oil with flow out as the air takes up the spacenow, cut the hosingthen, reattach the hosing to the levernow, undo the bleed nipple on the lever ( hole next to where the hosing go into the lever)next, push the fluid into the cylinder end until the oil or (water) starts to come out of the leverthen, put the bleed nipple back in and finally screw the bolt back in the cylinder trying not to get air in the system and then go out and ride( whilst doing all that make sure your oil does not spill on the brake pads)hope this helpsjackDo what this guy saying but if you are bleeding water then I'd rather take the brake off and do it under water. Like filling your sink up in the kitchen or bathroom or what ever. Then you'll know there won't be any air in the hosing! I do it all the time and no air at all.pAuL!! Quote Link to comment Share on other sites More sharing options...
