Computer Is Fooked. Help
  ReverendJQ said:
Ctrl, Alt, Del then shutdown tab
Log off from there then log back in.
That should work.
Doesn't solve the problem completely though.
Task manager isnt opening
  tomturd said:
Run adaware and spybot..
None of my icons work
  Scopse said:
If your that desperate I'd go for a re-format. Works wonders.
Hope you've got all your stuff backed up, or have the ability to back it up.
Thats not really an option
reboot pc
as soon as it starts restarting keep pressing F8 (do not hold it down)
when Windows menu appears select safe mode
when in safe mode do virus/spware scan
back up important documents (note you will not have USB support in safe mode)
or
remove hard drive and put it into another comp,
run scans on it
does it not even display by pressing the windows key on your desktop.
as the guys said run adaware ect. also avg might help sounds like a advanced trojan
just think yourself lucky you havent got one that opens and closes your cd drives.
have a good clearout of old files and your pc should be sorted
defo run spywares ect
