Hope Piston
Up'n'away
Hey
Quick question, after i took the pads out to replace them the silver pistons bits moves out and when i push one in the other pops out or if i equal them out the pads have a tiny gap not enough for the rotor..
What do i do?
Is it fooked?
Or do i need a bleed?
I duno!
CHeers
OK sorted, releived some pressure by letting out the tinest bit of oil, and that has squirted on the disk :@ .. Boiled the disk and sanded a layer of the pads and now the braking power isnt what it was :(
Any suggestions?
Will need to bed in again because of boiling the disc and sanding the pads.
Matt Rushton
Hmm i think your right .. it does, the brake is ok but it doesnt feel all that wall. I have some dot 4 , but how do i bleed hope? I am geusing you put a pipe on the bottom end and top it up through the top bit? Ah, now worries il search ;)
