Video Compression
Walleee
I got myself a PIMP xda Graphite Smartphone the other day.
It's fantastic for watching videos on in full screen, however all my videos are like 50+ MB and some big resolution which really isn't nescessary on the phone.
I've used media player movie maker to compress squince's 6th vid and using the default setting for windows pocket PC (fullscreen 218Kbs) gives a resolution of 320x240 and keep the audio quality nice too.
Is there any other software out there which can do what im after in a smaller package than WMM? It's such hassle having to import the vid first and then save it as a movie again.
I tried the nokia multimedia convertor but it fucl up the aspect ratio and won't work in full screen...
Can't advise on compression because I also use Movie Maker, but ff that phone is WM5 based, get TCPMP. It's a great media player for PDAs.
Linky (it's down at the moment, try later).
I used other programs for compressing in the past but they were slow and inefficient. Just stick to MM or if you want a really good compressor, download Premiere Pro and use the Adobe Media Encoder. You could also try DivX Create, it's got a setting for mobile devices but to play it you will need the program above.
You'll be wanting a program called M3 made by someone caled mysh. Its the best at changing ratios for phones. Super easy to use, only quite hard to track down.
If you add me to msn i can send you the 8mb installer for it. I can't seem to find a link to a current host anywhere on the internet :(
Cheers kris, Tried using that one you linked to janson but I duno which of the settings im looking for. :$
