Stripped Threads In My Frame
Alex.loves.boys
i rmeber seeing someon cable tied the moutns to frame, does it actually woirk?
lol
cheers
Works fine. But make sure you use a stainless steel one and remove the bolt from the mount.
Try local garage but chances are they won't go that small.
Tyler said he had a helicoil set...
Don't helicoil it, tap the mounts to M8 and screw in an M8->M5 steel insert (or whatever they're called).
It's a great thing, you'll never need to worry about stripping the threads again.
You might want to ask Biff about this, I know he had it done to his Python.
Correct me if i'm wrong but isnt that helicoling 'putting a steel insert into the frame'?
Matt Rushton
Matt Rushton
helicoiling isnt a fat insert that reduces the size of the thread like 8mm>5mm its just like a replacement thread that is inserted inside the old hoel of the same diameter
