wunderboy Posted March 29, 2007 Report Share Posted March 29, 2007 I need to bleed my Hope rear disc. I have searched the forum, but there is so much about bleeding maggies that I get lost in the comments. What fluid should I use, and will I be able to use the same bleed kit that my housemate uses on his Magura? Any insight will be greatly appreciated. Thanks, all. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted March 29, 2007 Report Share Posted March 29, 2007 dot oiland you dont use a syringe for hope, you take the resivoir cap off and let gravity do the work!you need an 8mm (i think) spanner at the slave end and you let the oil down like that...im really bad at explaining, someone please do a better job than me! Quote Link to comment Share on other sites More sharing options...
wunderboy Posted March 29, 2007 Author Report Share Posted March 29, 2007 (edited) That's cool! I looked on my lever and didn't see the same valve that my mate's Magura has. Are there multiple dot numbers or is dot fluid just dot fluid? Edited March 29, 2007 by wunderboy Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 29, 2007 Report Share Posted March 29, 2007 DOT5.1 for Hopes.Basically, where the bleet bolt is at the caliper, undo that, and put on some sort of piping, or something to 'catch' the old oil.Undo the resovoir cap, and slowly pour it in, until you reckon there's no more air in there.You must make sure the resovoir always has oil in it. - Often best to turn the lever so the resovoir is facing straight up.Once you're confident that it's got nothing but oil in it, do up the bleed bolt at the caliper, do a final top-up of oil in the resovoir, and do up the resovoir cap. - Try not to pinch the seal! Quote Link to comment Share on other sites More sharing options...
wunderboy Posted March 29, 2007 Author Report Share Posted March 29, 2007 Solid and clear... thanks! Quote Link to comment Share on other sites More sharing options...
