Echo Control Booster
Ryan Blackwell
wouldn't the spacing be too wide or am i being retarded?
Good question but yes it does fit. I had a creepy crawler on a echo lite. The booster needed slight filing down but not enough to need an angle grinder. I had no problems. Although i had to cut the bolts down slightly.
What frame you running. As im guessing different frames will allow you to use it others won't, a mate used one fine on a tmag with cc. You can just angle grind it to give some better cleareance anyway and they are really good stiff boosters. Got one i may sell if your interested pm me.
