STC Posted March 29, 2007 Report Share Posted March 29, 2007 Hey All,I'm having a problem with my bb and quick releases.1. Why is my bb clicking when I do backwheels? My friend told me it's my hub skipping but it's not2. Why is my front wheel keep moving to the left? Is there a problem with my quick releases?Comments welcome,Cheers,luke Quote Link to comment Share on other sites More sharing options...
Luano Posted March 29, 2007 Report Share Posted March 29, 2007 your wheel moving will be down to one side of the droupouts being bent slightly but i dont know about the hubyou cant really fix it properly without bending it back but the bend will be tiny Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted March 29, 2007 Report Share Posted March 29, 2007 get a new bb, if it still clicks then it is the hub! Quote Link to comment Share on other sites More sharing options...
STC Posted March 29, 2007 Author Report Share Posted March 29, 2007 your wheel moving will be down to one side of the droupouts being bent slightly but i dont know about the hubyou cant really fix it properly without bending it back but the bend will be tinyProberly but thanxs for the adviceget a new bb, if it still clicks then it is the hub!Might get a new bb thanxs for the advice Quote Link to comment Share on other sites More sharing options...
monkeymoped Posted March 29, 2007 Report Share Posted March 29, 2007 sounds like the bb does need changing, but as mentioned before check the hub aswell so you don't spend money you don't have to Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted March 29, 2007 Report Share Posted March 29, 2007 The BB clicking might just be play in the threads, so whip it out, give everything a good greasing then stick it back together nice and snug.Alun Quote Link to comment Share on other sites More sharing options...
STC Posted March 29, 2007 Author Report Share Posted March 29, 2007 The BB clicking might just be play in the threads, so whip it out, give everything a good greasing then stick it back together nice and snug.AlunOh I might try that thanxs Quote Link to comment Share on other sites More sharing options...
Rumplestiltskin Posted March 29, 2007 Report Share Posted March 29, 2007 Depending on the hub you've got the movement could be caused by loose cones maybe? If the wheel remains straight between your forks but moves laterally to the left like a bead sliding along an abacus, it might be the hub cones are loose - I had a bit of hassle like this with Shimano hubs when I used to run them. If the movements more like a move to the left then back to a straight line, the wheel could be buckled, or the QR's bent (although I think that might just permanently incline the wheel to the left). Maybe its just knackered and is slipping out of the left hand drop out cos its not tight enough? Its probably nothing out of the list above, but it might be worth checking for them just in case. Quote Link to comment Share on other sites More sharing options...
STC Posted March 30, 2007 Author Report Share Posted March 30, 2007 Depending on the hub you've got the movement could be caused by loose cones maybe? If the wheel remains straight between your forks but moves laterally to the left like a bead sliding along an abacus, it might be the hub cones are loose - I had a bit of hassle like this with Shimano hubs when I used to run them. If the movements more like a move to the left then back to a straight line, the wheel could be buckled, or the QR's bent (although I think that might just permanently incline the wheel to the left). Maybe its just knackered and is slipping out of the left hand drop out cos its not tight enough? Its probably nothing out of the list above, but it might be worth checking for them just in case. It could be that Quote Link to comment Share on other sites More sharing options...
