Kmc Kool Chain
A few people I know have taken their split link out as they know alot of people who's chains have snapped because of it.
I think it all depends how hard you ride =]
You would probably be better off without it if you could spare some length of the chain going
(Y)
{Spudrik}
i personally dont mind split links... at 1 stage i was running like 5 of them and it was never those pins that snapped upto you really! i dont use too much / any tesion.... so up to you if possible dont use it... if you cba to take a load of time just use the link
Mine always used to break or get bent open. Fitting a chain properly only takes 2-3 minutes anyway and most of that is just winding the chain tool.
Right, push the pin back through slightly so its even on both sides, if its still stiff then put a screw driver between the link and jerk it about, put a bit of force into it (prising it open slightly), it should then be loose.
............or two small allen keys either side of the stiff join then twist them in opposite directions.
