Fitting A Star Fangled Nut Thingy?
The Hitcher
Hi all, I am just fitting some new forks, and I have come across a problem, the star nut thingy that goes in the forks. How are you meant to fit it and how low etc does it have to be???
Any help muchly appreciated.
Cheeers! (Y)
You will need a tool to do it properly, ie getting it in straight, and it doesn't need to be too far down as the bolt that screws into it wont fit...
Best bet is to get a shop to fit it, its not exactly a hard job for them.
Cheers, Rorz!
just poke it in.
be very gentle, you dont want it wonky, not too far in either due to the size of said bolt.
if it goes tits up, poke it out the bottom and :
A) Try again, learning from your mistakes
B ) Swear alot because its screwed (should be fine though)
C) Take it to a shop admitting defeat.
matt
mine went in fine in my dirt jumper, just ease it in.
Edited by 20inchsuperstar
Some sound advice, many thanks, i shall give it a go when my forks arrive. using a socket sounds good, can get it straight.
My bikes already taken enough swearing trying to build it up, i swear it wants me to fail!
(Y)(Y)
Don't they all! Good luck + keep at it.
Rorz!
