Is There Alot Of Diference?
bcourt2005
The main differences with the hs33 and the hs11 is the lever , the slave cylinders are the same, also the pure fact that the hs33 is much more powerful than hs11s , this is because the master cylinder on an hs33 is much larger than the hs11s ones which gives the hs33 more power. The hs11 lever bodies are made from plastic whereas the hs33 lever body is made from metal. Finally , the hs11 uses 3 finger brake levers and the hs33 uses 2 finger ones.
hope I have helped you , Nile
