trialsmasterkylez1 Posted March 26, 2007 Report Share Posted March 26, 2007 Hi, does anyone no if i could swap my HS 11 levers' to HS 33 levers? Also would i have to change any parts if this works?Kyle. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 26, 2007 Report Share Posted March 26, 2007 yeah, it will be fine as they are identical except for the levers Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 26, 2007 Report Share Posted March 26, 2007 It dose work there all the same cylinders i believe all the fittings are the same so should be alright.Cheers. Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted March 26, 2007 Report Share Posted March 26, 2007 The slave cylinders are the same however if you want to change it to an hs33 lever , u need to cut the barbed fitting off the hose at the lever on the hs11 , throw it away and slide a new olive onto the fresh cut hose and reinsert it back and screw the hose nut on (if u have a brand new lever , the olive and the nut will be included). Once this is done , its now an hs33! now you can be confident with your brake , well thats from my experience at least...hope I have helped , Nile Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 28, 2007 Report Share Posted March 28, 2007 If u r going 2 get a lever brand new, (this is off tarty's prices) @ £40, why not bite the bullet and get a complete hs33 system @ £65 plus u would get the 5 year leakproof warranty. Quote Link to comment Share on other sites More sharing options...
