ned1 Posted March 25, 2007 Report Share Posted March 25, 2007 hi, im just wondering whether it would be ok to bleed my hope mono trial disc on dot 4 rather than dot 5.1.thankschrisps. it says on the back of the dot 4 brake fluid that i can mix it with dot 5.1 Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted March 25, 2007 Report Share Posted March 25, 2007 If it says so on the cylinder then yes ~Matty Quote Link to comment Share on other sites More sharing options...
Mike W Posted March 25, 2007 Report Share Posted March 25, 2007 Hey, on the top cap of my mono its says only use dot 4 or dot 5.1 so i would of thought it will be ok mike W Quote Link to comment Share on other sites More sharing options...
ned1 Posted March 25, 2007 Author Report Share Posted March 25, 2007 (edited) hope says use 5.1 althoiugh i have some spare dot 4 in my garage. i was just pinting out that i am able to mix the 5.1 and 4..sorry for the confusion Edited March 25, 2007 by ned1 Quote Link to comment Share on other sites More sharing options...
flas12345 Posted March 26, 2007 Report Share Posted March 26, 2007 usually on top of the cylinder it will say 'use dot 4 or 5.1' so yeah dot 4 will work fine.cheers lou. Quote Link to comment Share on other sites More sharing options...
WeeGee Posted March 27, 2007 Report Share Posted March 27, 2007 You can put Dot 4 with 5.1, although for the sake of a few quid at Halfords I'd always stick with what's already in the brake system! Considering you have £130 of brake it's worth spending a bit extra to keep the system as pure as possible. Quote Link to comment Share on other sites More sharing options...
