Joy Pads - Adding Some Bite
Phil H
Fitted some of Ali C's Joy pads last night. Went out for a little 5 minute sesh on the curbs. The power was good and it wasn't slipping at all but it had no bite atall.
Whereas where I had red onza pads I had immense bite and as I pulled in the lever it just stopped dead and I could really feel the brake biting now its just mushy and nasty.
I've got a medium/light grinded rim which isn't particularly sharp but with the onza pads were working beasty. Like I said it isn't slipping one bit just doesn't feel nice to hold.
I'm going to try setting the brake up a couple more times. I mgiht try white spirit then methelated spirit etc to clean the rim.
What else? Do they need bedding in time?
Phil
ride with them for more than 5 mintues?
but seriously some brake pads can take like up to a few hours to bed in give em a chance!
Allritey rode another 15 mins this afternoon.
Going out in 10. Properly annoying I have all this coursework (N)
Phil
Edited by Phil_Onza
So why did you change pads in the first place?
They were worn down quite alot and besides they were complete cack before I ordered the new pads. It was just since I got a new bleed that they got nice and the positioning was spot on.
I just rode for half an hour. Was hitting the highest peddle hop/occasional tap I have ever done, kept landing on the edge and very slighlty slipping. So I put the pads closer but what im finding is that only one piston is moving that well as well as them having not much bite and this is the reason I keep having to re-set the pads.
Rather Annoying. I'll give them a couple of days and see what happens.
Phil
As Kris said, removing my booster made my Joypads bite like crazy. As for bedding in, I seem to remember it taking atleast 2 days, which was abnormally long but I think these pads are quite a hard compound therefore its understandable that after just 15mins they are still abit poo.
Just keep chucking water on and riding round doing quick bursts of braking, let the water dry naturally and thats how I get my pads to bed in.
Wind the TPA off, set 'em up again? Sounds like either you've got a sticking piston and just need to lube them up, or you just need to use less TPA...
I swear, half the time people should set up their brakes properly before getting pissed off with pads. Look at what guys like the Martins did on good old Koolstops!!
it took my phat pads a good few days to bed in as it was raining all the time but i got simp to put a grind on only light medium and it was insane did my biggest backwheel in the rain (bar height) and it was squeeking and locking i was well chuffed best pads ive used ever
Dont suppose your running a stupidly stiff booster on an ordinarily rigid frame are you? My joypads were heaps better after i'd removed my control booster. They had noise, bite and lock. I was well chuffed.
Cheap fix too :D
I have a T-Rex and a fat echo control booster. Worth a try!
Cheers,Phil
I have tried setting it up a fair few times.
Phil
Ah I see, good stuff. Haven't tried the water approach (thought that was jsut for disks) Well I rode yesterday and I put a good 3/4 hours tonight. They are still fairly grippy but on the very edge of logs move a tiny bit. Nothing too bad jsut not feeling the bite. I do feel a sligh improvement since yesterday.
Phil
Ah fair doos. I suppose its only been about 6/7 hours of riding with the new pads. I'll start adding water and see what happens in time.
Phil
