Small Direction Hops
mad max
How the hell do you change direction while on the back wheel? (hop round in circles)
Got any top tips to speed up learning process, i am really struggling with this :$
Thanks for any help.
Oh, and i have used the search.
The key to is is being as high as you can, have the bars right in and the bike at a preety vertical angle. This gives you alot more control than if the front is low and your ass is sticking out.
When you have this vertical position slightly rurn the handlebars in the direction you want to go.
Things like this just come with time, keep riding and you'll have it in no time.
Phil
Its like you have to turn your arms. I find not like bend your arms as in your steering but like shuffle your arms and turn your body but thats just me , lol :)
~Matty
I meant bend your arms as in downwards, you get more control, try it. So they are in this shape _/
You need to have your bike nearly vertical, so you have more control. And i find you use your lower body to shift your back wheel round and your front should follow, push the way you want to go using your feet, at the same time turn your upper body round (Y) I wouldn't try for ages trying to do it, and as someone said, it will just come naturally to you as you keep riding.
Thanks for the tips, i do need to be more vertical and lower my elbows more.
I find it easer getting help from here rather than a how to site (Y)
