charlie >est< Posted March 24, 2007 Report Share Posted March 24, 2007 Hi,I am thinking of buying Echo Lite forks but I am thinking. I might need 4 bolt clamps to mount my brakes to the frame because the Echo Lite forks are back mounted and may hit the frame.Can I use Evo 2's or do i need 4bm?Thanks,Charlie Quote Link to comment Share on other sites More sharing options...
xris_x Posted March 24, 2007 Report Share Posted March 24, 2007 Hi,I am thinking of buying Echo Lite forks but I am thinking. I might need 4 bolt clamps to mount my brakes to the frame because the Echo Lite forks are back mounted and may hit the frame.Can I use Evo 2's or do i need 4bm?Thanks,CharlieHey there,You will need 4-bolt clamps. The Echo Lite forks with rear-mounted brake mounts are for Magura brakes. You would only use EVO 2 mounts if you buy the Echo Lite forks with the 2 studs sticking out at the front.Hope it's clear to you Chris Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 24, 2007 Author Report Share Posted March 24, 2007 Hey there,You will need 4-bolt clamps. The Echo Lite forks with rear-mounted brake mounts are for Magura brakes. You would only use EVO 2 mounts if you buy the Echo Lite forks with the 2 studs sticking out at the front.Hope it's clear to you ChrisI have canti stud adaptors currently with my magura HS33 Evo 2 Mounts.Would this work or is the mounting system too big? Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 24, 2007 Report Share Posted March 24, 2007 I'm pretty sure that if you mount the Evo 2 mounts upside down you can secure them with 4 screws Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 24, 2007 Report Share Posted March 24, 2007 Would this work or is the mounting system too big?That setup will go straight onto the V-Brake mount forks Alternatively, you could purchase 4-Bolt forks and 4-Bolt mounts. Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 24, 2007 Author Report Share Posted March 24, 2007 That setup will go straight onto the V-Brake mount forks Alternatively, you could purchase 4-Bolt forks and 4-Bolt mounts.Ok, thanks.So i have to buy four bolt clamps if I want four bolt mounts.The only reason I asked is that I have canti stud adaptor's that came with my t-pro. Quote Link to comment Share on other sites More sharing options...
