T-pro
mini rayner
Hi do u run a ACS free wheel, if so the lock ring may have come lose, You need to tighten it up with a little flat head screw driver, And put it in the little hole in the lock ring, And turn the crank arm around till its tight.
hope i helped paul bell.
Edited by paulbell123
Right.... where shall I start... what bike is it. all your telling us is that is a T-Pro it could be a 2000, 2003, 2005, 2007 what? and were exactly is the noise coming from and can you feel it?
You must explain things, remember we are not psychic's.
I did have a noise coming from my bottom bracket when I pedal on my T-Pro 07.
BB's do need lubracation of some sort every now and then.
Squirt some WD40 in side the BB then spin the pedals fast (or just ride it quickly).
I The noise should stop within a few minutes.
Hope this helps.
Charlie
Edited by charlie >est<
If it's coming from the drivechain:
Check the freewheel. - If it's loose, tighten it, or clean it.
Check the chain. - Could have tight spots...
Check the pedals. - They can sometimes creak, try greasing and tightening the bearings.
Check the BB/Cranks. - Clean out the tapers, and oil/grease it a little bit.
If it's from the steering.
Check the headset. - Clean and re-grease the bearings, and make sure there's no dirt in it. Also make sure it's not loose.
Check the bars. - Maybe cracked. Also take the out the stem, and give them a wipe down, also the clamp part of the stem. Sometimes they get dirty, and just creeaakk.
Check the forks. - Could be cracked?
Think that's it? :unsure:
Hope this helps.
Charlie
Cheers for the help i did what you said and it works fine now
cheers
MY mate had this problem but he just tightened his freewheel and cranks and its ok now (Well I think). I also have this problem when my freewheel comes loose :P So just tighten the old freewheel bud and see what happens from there (Y)
Goodluck-
~Matty
cheers for the help i did what you said and it works fine now
cheers
All my drive train like freewheel and cranks and bb
(if that is part of the drivetrain, lol) but anyway there all messed up really and I need new cranks,freewheel.
Ps. This is all I need doing to my bike then it be a good bike :)
~Matty
Edited by Matt-y
