Ko-bikes Bottom Bracket (have Changed Topic) Look In
N Roach
hey,
need to get my Ko-bikes bottom bracket out my frame, but my tool does'nt fit over the spacers! does anyone have this bottom bracket, and know which tool to use to remove it?
cheers
nafan
Edited by chocolate_bikes
The zona zip bash fits the zona zip frame without any spacers, so the rubber is a different shape.
Put the two bolts at the back in as far as, so that it can move about but the bolt has a good purchase on the thread, then worm the rubber in the gap and squash it down as much as possible, then secure it with a zip tie round the frame, you should be able to get the bolt in then tighten them all up and remove the zip tie.
You need a Park Tool BB tool. One that fits onto a socket.
I have/had the same problem with my FSA Platinum Pro BB, I had a standard Shimano tool, and it wouldn't go over the spacers, where as the Park Tool one does.
