Making My Own Bashring... Help?
Tom_
Basically i am to poor to be able to afford a bash ring at the moment.. soooo i decided to make one. I have some chequer plat stuff which is about 4mm thick, basically i want to know what i have to do to it (other than cut it into a circle bigger than my tensile) to make it work out ok.....
cheers.
As long as you have enough clearance and it fits snugly on the crank arm, I don't see why it needs to be that perfect, just make sure you get your dimensions right, and make it a few mil bigger on the outside too 'cos then it won't wear out as quickly (obviously)
Nathan :)
