Best Brake Pads For Tar?
jack_t-comp
In all honesty, if you use tar then all brake pads will do the same job... right from standard Magura black pads through to Rock Pads. The tar prevents the brake pad from actually touching the rim, its a barrier, so the compound of the pad is completely insignificant.
Having said all that though, some people will say some pads 'take tar' better than others..!
http://www.trials-forum.co.uk/forum/index....showtopic=41481
check that topic it's a full topic about brake pads all the information you need will be in there. As in refernce to your question i would recomend zoo! pads, i've never used them myself although i have been told by munerous other riders that there the bee's knees on a clean rim with tar.
thanks
chris (Y)
