Alex.loves.boys Posted March 18, 2007 Report Share Posted March 18, 2007 HeyRight, ive been putting of fixing my stock but now i need to.I snapped my mech hanger a few weeks ago..so I had ago at making a tensioner that bolts onto the axel, now tension is dandy and that, BUT when i put pressure on the cranks ie gapping theres a slipping feeling/noise. its very scary and i dont have a clue what it is?its not the tenioner im pretty sure, although im going to whack a big fat roller on there instead of jockey wheel..i can afford to buy a 74kingz tensioner, but ive herd mixed opinons on them, are they actually any good?Thanks Quote Link to comment Share on other sites More sharing options...
Token Posted March 18, 2007 Report Share Posted March 18, 2007 You have a rear cassette? If you have then does the tensioner pull on the axel? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 18, 2007 Report Share Posted March 18, 2007 is your wheel done up enough?no the 74kingz tensioner is shit Quote Link to comment Share on other sites More sharing options...
GyTrials Posted March 18, 2007 Report Share Posted March 18, 2007 Sounds like there is not enough chain wrap, need to get your chain wrapped around the cassete morei had the same problem and a rolholf tensioner sorted me out nicelyhope this helpsSteve Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 18, 2007 Report Share Posted March 18, 2007 is your wheel done up enough?no the 74kingz tensioner is shit REALLY GOOD! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 18, 2007 Report Share Posted March 18, 2007 moaning at me...when you have seen daves one you would understand why i believe it is so wank Quote Link to comment Share on other sites More sharing options...
B.E.A.U Posted March 18, 2007 Report Share Posted March 18, 2007 what cranks you running if there zoo etc they may of threaded Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 18, 2007 Report Share Posted March 18, 2007 have you changed the chainring or chain? Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 19, 2007 Report Share Posted March 19, 2007 when you have seen daves one you would understand why i believe it is so wankI can understand why you think so ash, if not installed correctly they can be a bit wank (I bent mine a bit installing it, so read the instructions carfully everyone) but mine is still working quite nicley. Quote Link to comment Share on other sites More sharing options...
Prawny Baby Posted March 19, 2007 Report Share Posted March 19, 2007 dont go for the 74kingz one al, all the ones ive seen have been pretty shite in my opinion!chainreaction do a slightly cheaper tensioner thats very like the rohloff now, or just make a bigman style one! Quote Link to comment Share on other sites More sharing options...
basher Posted March 19, 2007 Report Share Posted March 19, 2007 If its more like a slip and not a skip it could be your rachet ring is turning in you hubshell as the threads have stripped i had this problem with my profile hub. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 19, 2007 Report Share Posted March 19, 2007 I can understand why you think so ash, if not installed correctly they can be a bit wank (I bent mine a bit installing it, so read the instructions carfully everyone) but mine is still working quite nicley. yeah, but the bolts fell out too so it had to be cable tied, he did install it correctly Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted March 20, 2007 Author Report Share Posted March 20, 2007 If its more like a slip and not a skip it could be your rachet ring is turning in you hubshell as the threads have stripped i had this problem with my profile hub.i think it might be that how do i check?> Quote Link to comment Share on other sites More sharing options...
