Engagement Speed
ogre
For those of you who're debating a front freewheel/freehub you might find this usefull.
working out how many degrees it take to engage a freehub/rear freewheel (it doesn't matter for a front freewheel because you don't benefeit from the gears, it's just down to engagements,where you just divide the number of engagements into 360)
divide the number of teeth you've got up front by what you've got on the rear:
i.e for the standard mod gear 18/12 you'd get 1.5 (so every 360 your cranks spin when pedaling you're wheel spins 540 (360 x 1.5))
times the number you get from the ratio by the number of engagements your hub/freewheel has.
i.e for a profile 1.5 x 48 = 72. (the new number is bassicly the number of clicks you'de get spinning the cranks 360)
divide 360 by the "new" number of engagements, the value is the most you'd have to pedal to catch an engagement
i.e 360/72 = 5degrees
Quick referance hubs/freewheel engagements:
ACS claw 36ep
Tensile 60ep
Monty 72ep
Tryall 108ep
Eno 72ep
Echo 72ep
Hope Xc 21ep?
Hope Mono 21ep?
Hope Pro2 48ep
Profile 48ep
Deng freehubs 48ep
Chris King 72ep
(very bored ogre)
  • 3 weeks later...
No it wouldn't It just means your cranks would move more before it engages. Whether you have a 2cm crank or a 200cm crank, you still have to rotate it the same amount, its just it actually moves more at the end
Good post ogre, very easy to follow
  • 3 weeks later...
after ash's post about crank length for those of you who want to know how far you want to move your crank:
once you've found out how many degrees your engagements are (see above)
Double the your crank length (giving the equivalent of a diameter)
158 = 316
160 = 320
165 = 330
170 = 340
175 = 350
multiply the new value by 3.14 (Pi)
158 = 316 = 992
160 = 320 = 1005
165 = 330 = 1036
170 = 340 = 1068
175 = 350 = 1099
(i've kept them as whole numbers 'cause i'm lazy)
now divide that number by 360 and times that by the number of degrees it takes for you to get an engagment
i.e an 175mm crank running 18-12 on a profile would move 15.26mm at most (assuming the chain is tight).
and a 158mm crank running 18-12 on a profile would move 13.78mm at most (i wonder if anyone'll run shorter cranks if they knew they'd get a slightly faster engagement :rolleyes: )
happy ash?
christ.
so i would get more power with shorter cranks? gay ive got 175, no wonder everyone can gap so bloody far
no you'd feel the engagement sooner, but your gear would feel harder because you don't get as much leverage fom a shorter crank so then you'd run a lower gear and get a slower engagement anyway :P ffw ***!
No the engagment would be the same, just because you were in a lighter gear not able to gap as far?
no it wouldn't (assuming your running a freehub, if your running ffw it wouldn't make a difference) i don't think gaps come down to gearing so much as technique + and just hucking yourself. don't turn my thread into a discussion about gappping please?
Edited by ogre
  • 3 weeks later...
christ.
Nah, stick with 175s. Bosh on a harder gear, and it'll feel like your old gear with 165mm cranks, but you'll have more power. Worked OK for me on mods, got my gaps pretty decent in the end.
  • 1 month later...
Technically, if i'm being picky, a profile hub actually only has 24 engagement points within the hub.
One revolution of the hub does create 48 engagemenets, because 2 pawls engage at one point, then another 2 engage half way in between, doubling the number of engagements from 24 to 48.
To look at it in terms of reliability, you could say that this means the engagments are going to be more reliable. This is becasue the space taken up on the outside surface of the inner of the hub, is only filled with 24 engagements, not 48, which means they can be double the size, making the pawls engage deeper and have more contact against the hub.
In the event of a slip, there are 2 pawls waiting to engage hald an engagement away, and are more likely going to catch than a hub with more engagements, because the size of the engagements and depth, determines the strength of the spring required to push the pawls into them. Because the engagements are bigger, the springs are that little bit stronger, to push the pawl deep into the engagement.
Profiles are very safe hubs for trials for these reasons, and obviously others.
I don't know if any of the other systems work in this way, maybe they do.
Bongo
