Danny Kearns Posted March 17, 2007 Report Share Posted March 17, 2007 Hi there. I would just like to know. How do you replace the Master Cylinder in Magura 2004's. I hope i am mentioning the right thing. It is the bit what the thing in your lever pushes against to moves the pads.Please help me out.Dan......... Quote Link to comment Share on other sites More sharing options...
Barbara Logan-Price Posted March 17, 2007 Report Share Posted March 17, 2007 i dont think you can Quote Link to comment Share on other sites More sharing options...
nickyw Posted March 17, 2007 Report Share Posted March 17, 2007 If ive thought right what your talking about,Is it the the part were the lever blade goes? If so,Then..Take the whole lever off danny baby...You should see a circle black peice what is in the lever (Think this is the cylinder itslef).Push it as hard as you can (pure daniel kearns muscle will do) and it should push back and come out a little bit (or straight out).If it comes out a little bit,Get some pliers and pull it out. Then inisde,You should see a spring and loads of oil. Could be totally wrong how you do it,But thats how mine came out. Quote Link to comment Share on other sites More sharing options...
James Quigley Posted March 17, 2007 Report Share Posted March 17, 2007 why do you need to replace it?If it's just 'sticking' take it out (the black bit with the spring) thorougly clean it all, drown in a silicon lubricant (NOT silicon sealant) and push it all back together, should work fine then. Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted March 17, 2007 Report Share Posted March 17, 2007 put a 2 mill allen key throught the bleed hole and push hard . Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted March 17, 2007 Author Report Share Posted March 17, 2007 All fixed thanks to Stan Shaw (via Msn) and (Nicky w). And everybody else who give tips. Thanks everybody all sorted.Dan............ Quote Link to comment Share on other sites More sharing options...
eskimo Posted March 17, 2007 Report Share Posted March 17, 2007 Sorry to bump it as your sorted but what was the problem in the first place? I'm curious to how you broke it if you did? Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted March 17, 2007 Author Report Share Posted March 17, 2007 Right ok buddy. What was happening was, I was pulling the brake lever. before the pads even hit the rim, the lever locked solid when pulled it and you couldnt squeeze it backwards for nothing. Basically my brake pads woudnt even get to the rim and the lever had pulled in as far as it wanted to go.Dan.................... Quote Link to comment Share on other sites More sharing options...
