charlie >est< Posted March 15, 2007 Report Share Posted March 15, 2007 (edited) Will any kind of snail cams fit T-Pro 05 and 07?What kind do you reccomend.Im hoping to order soon. Edited March 15, 2007 by charlie >est< Quote Link to comment Share on other sites More sharing options...
Barbra Posted March 15, 2007 Report Share Posted March 15, 2007 theres no hole in the frame for the Cams to go into, so no snail cams won't fit. Only chain tugs Quote Link to comment Share on other sites More sharing options...
flas12345 Posted March 15, 2007 Report Share Posted March 15, 2007 (edited) theres no hole in the frame for the Cams to go into, so no snail cams won't fit. Only chain tugs well in the 05 and the 06 frames there are holes for them because there is in mine and my mate is running snail cams in his frame and they are mint.he is using the ZHI cams they are very good also the fresh products cams are good.cheers lou. Edited March 15, 2007 by flas12345 Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 16, 2007 Author Report Share Posted March 16, 2007 well in the 05 and the 06 frames there are holes for them because there is in mine and my mate is running snail cams in his frame and they are mint.he is using the ZHI cams they are very good also the fresh products cams are good.cheers lou.Im know for a fact there is threaded holes next to the axle but i dont realy know how snail cams work. ill post a pic. Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted March 16, 2007 Report Share Posted March 16, 2007 yes they do fit. Quote Link to comment Share on other sites More sharing options...
Ryan. Posted March 16, 2007 Report Share Posted March 16, 2007 chain tugs ***, i had themk on my old t-pro, love em Quote Link to comment Share on other sites More sharing options...
padarik Posted March 16, 2007 Report Share Posted March 16, 2007 i know for a fact they fit the o5 o6 ones , recomend they zhi ones as they have more notches then any others on the market for better wheel allignment and come in some dashing colours im running fresh products but not on t pro and they have really deep notches so dont know what they will be like on a onza Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 16, 2007 Author Report Share Posted March 16, 2007 chain tugs ***, i had themk on my old t-pro, love em I dont want chain tugs that the problem.i know for a fact they fit the o5 o6 ones , recomend they zhi ones as they have more notches then any others on the market for better wheel allignment and come in some dashing colours im running fresh products but not on t pro and they have really deep notches so dont know what they will be like on a onza Yeah, I like the look of the Zhi ones.Were shall I get them from? Quote Link to comment Share on other sites More sharing options...
Muel Posted March 16, 2007 Report Share Posted March 16, 2007 The hole is threaded for the pin to screw into, then the snail cam runs against that. Quote Link to comment Share on other sites More sharing options...
poopipe Posted March 16, 2007 Report Share Posted March 16, 2007 The hole is threaded for the pin to screw into, then the snail cam runs against that.yes it is and 05 t-pro frames have themnotched snail cams are shit - get the smooth steel ones from tarty Quote Link to comment Share on other sites More sharing options...
Ryan. Posted March 16, 2007 Report Share Posted March 16, 2007 if you still want ZHI cams look on www.trialsman.co.uk Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 16, 2007 Author Report Share Posted March 16, 2007 The hole is threaded for the pin to screw into, then the snail cam runs against that.You have the same cranks as me, are you having problems with the bolt coming loose?My bolt comes loose after about 10 minutes riding. Quote Link to comment Share on other sites More sharing options...
samo Posted March 16, 2007 Report Share Posted March 16, 2007 i would recomend fresh products because they are nice and big Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 17, 2007 Author Report Share Posted March 17, 2007 Cheers boys I ordered the Viz ones from trialsman Quote Link to comment Share on other sites More sharing options...
padarik Posted March 17, 2007 Report Share Posted March 17, 2007 yes it is and 05 t-pro frames have themnotched snail cams are shit - get the smooth steel ones from tartywheel alignment is limated but me and a few others have had trouble with the wheel just moving on smooth cams , threaded hole on the drop out is a simple m5 thread, and zhi cams are available from trials man Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted March 17, 2007 Report Share Posted March 17, 2007 Im know for a fact there is threaded holes next to the axle but i dont realy know how snail cams work. ill post a pic.In my opinon, snail cams are absolouter wank.If you have the option of runnig chain tugs then do it.There so much better. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 19, 2007 Report Share Posted March 19, 2007 Charlie the reason you dont like chain tugs is because you got absolute pants ones on your t pro. and to make that even worse you put them on wrong. so i advise you buy some good chain tugs and put them on correct. this way your wheel wont move. they are alot cheaper aswell Quote Link to comment Share on other sites More sharing options...
charlie >est< Posted March 19, 2007 Author Report Share Posted March 19, 2007 Charlie the reason you dont like chain tugs is because you got absolute pants ones on your t pro. and to make that even worse you put them on wrong. so i advise you buy some good chain tugs and put them on correct. this way your wheel wont move. they are alot cheaper aswellI prefer the snail cams.1. They dont damage your frame.2. They dont stick out.3. The are stronger (so ive heard)And I dont like twisting that little bolt in forever and continuously hitting my spokes, only managing to do about 1/8 of a turn. Quote Link to comment Share on other sites More sharing options...
