Ryan Blackwell Posted March 8, 2007 Report Share Posted March 8, 2007 Hey people im curious as to weather a brake booster makes the brake lock anymore because ino it stops frame flex but im wondering were the extra power is converted into.Cheers Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted March 8, 2007 Report Share Posted March 8, 2007 Well as the magura slave power isn't being used to push the chain stays apart (because the booster stops the flex), more power goes onto the rim Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 8, 2007 Author Report Share Posted March 8, 2007 Is there alot of diffrence or just a tiny bit.Cheers for the reply. Quote Link to comment Share on other sites More sharing options...
The Duck Posted March 8, 2007 Report Share Posted March 8, 2007 I found it made a pretty big difference... well worth getting one if you ask me... Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 8, 2007 Author Report Share Posted March 8, 2007 I have an echo 4 bolt sitting here but havent got it on yet but im going to do it now sounds like its worth it Quote Link to comment Share on other sites More sharing options...
Oskar Posted March 8, 2007 Report Share Posted March 8, 2007 on my bike the brake gets worse when i have a booster... Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 8, 2007 Author Report Share Posted March 8, 2007 Lol really how dose that work then ino it makes my pads sound shite but i dont really mind. Quote Link to comment Share on other sites More sharing options...
Waddy Posted March 8, 2007 Report Share Posted March 8, 2007 on my bike the brake gets worse when i have a booster...me too, my brake is ace without a booster, but is abit lacking with. slips alot Quote Link to comment Share on other sites More sharing options...
Endohopper Posted March 8, 2007 Report Share Posted March 8, 2007 Where's Mr. Heatsink's reply ? Wanna hear the ultra technical version and will continue to check back untill I read the phrase " finite element analysis . " Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted March 8, 2007 Report Share Posted March 8, 2007 its 6 of one and half a dosen of the other with a brake booster.On one hand it stiffens the brake up and stops the frame flexing but in doing that it makes the lever feel a lot harder. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2007 Report Share Posted March 8, 2007 The way I see it: Your wheel should be locked before your frame starts to flex. Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted March 8, 2007 Report Share Posted March 8, 2007 i think brake boosters are mint and i dont mind losing my squeak for loadsa power and if u run a smooth rim and zoo pads its still loud Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2007 Report Share Posted March 8, 2007 i think brake boosters are mint and i dont mind losing my squeak for loadsa power and if u run a smooth rim and zoo pads its still loud Noise isn't really something I look for in a brake im more concerned about wether it locks but f**k me koxx brown's melted with a turbo lighter on a fresh grind are soo noisey. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted March 9, 2007 Report Share Posted March 9, 2007 on my bike the brake gets worse when i have a booster...Ha ha, seems to be the case for me too. My pads make an annoying swoosh noise and slip a bit, never used to back on 2 bolts... so i'm gonna try not running an echo booster tomorrow see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted March 9, 2007 Report Share Posted March 9, 2007 i must have one of the stiffest back ends ever known to man, my zoo has all the funky braces on it to stiffen it up, and a fat arse echo control booster, i love it! made quite a bit of difference to me, everyones experience with boosters is different, some love, some loath. it happensmatt Quote Link to comment Share on other sites More sharing options...
MSM Posted March 12, 2007 Report Share Posted March 12, 2007 Just a thought... Maybe some of the "my brake doesn't work as well after fitting a booster" people might not have the brake pad's setup quite as well as they were before fitting the booster. I found a big improvement whenever I fitted a booster to a rim brake setup, and I am a fair bit bigger than average, so my brakes have to work a lot harder than for most. An HS33 with a shimano carbon booster converted to 4 bolt fitment on an echo hifi frame with plasmatic CRMs worked extremely well, for a rim brake. Quote Link to comment Share on other sites More sharing options...
joe b Posted March 13, 2007 Report Share Posted March 13, 2007 on my bike the brake gets worse when i have a booster...Same... my brake is ace without a booster, but is abit lacking with. slips alotSame... My pads make an annoying swoosh noise and slip a bitSame... Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
will Posted March 13, 2007 Report Share Posted March 13, 2007 if you hit a line and your brake slips, its a good sign that your body hasnt got enough extension. Do some stretches and get a better body position. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2007 Report Share Posted March 13, 2007 if you hit a line and your brake slips, its a good sign that your body hasnt got enough extension. Do some stretches and get a better body position.what? Fair enough I can see where your coming from but body extension is one of the last thing's you think about when it comes to brakes slipping. If it is the case that your not making it high enough, your tyre would slip rather than your brake, because by your explanation, it wouldn't be the brake, rather the rider causing the problem'If your brake slips, you've got the back wheel onto the ledge,(it can't slip if it's not holding on something?) if your brake didn't slip you'd stay there unless like I said your tyres are shit. Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 13, 2007 Author Report Share Posted March 13, 2007 Ok so i tried to put my booster on and my pads wont go out far enough so there rubbing really badly and the wheel just locks but when i take the booster off the brakes have loads of room.Whats the deal with that?Cheers. Quote Link to comment Share on other sites More sharing options...
Ryan. Posted March 13, 2007 Report Share Posted March 13, 2007 looks like your going to need off-set brake mounts...i think tensile just brought some out Quote Link to comment Share on other sites More sharing options...
Token Posted March 13, 2007 Report Share Posted March 13, 2007 yeah I'm using tensile off-set mounts, they're pretty good. Compensate for the silly wide 48mm wide echo rims.As for boosters making your brake worse, I can't really see how thats possible? Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted March 13, 2007 Author Report Share Posted March 13, 2007 But thats what i dont get without the booster they fit so why dont they if i have the booster on. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted March 13, 2007 Report Share Posted March 13, 2007 yeah I'm using tensile off-set mounts, they're pretty good. Compensate for the silly wide 48mm wide echo rims.As for boosters making your brake worse, I can't really see how thats possible?Neither do i, but it seems like it does for me. Quote Link to comment Share on other sites More sharing options...
will Posted March 13, 2007 Report Share Posted March 13, 2007 what? Fair enough I can see where your coming from but body extension is one of the last thing's you think about when it comes to brakes slipping. If it is the case that your not making it high enough, your tyre would slip rather than your brake, because by your explanation, it wouldn't be the brake, rather the rider causing the problem'If your brake slips, you've got the back wheel onto the ledge,(it can't slip if it's not holding on something?) if your brake didn't slip you'd stay there unless like I said your tyres are shit.Yeah fair point. But I stand by my previous comment. If you keep doing the same line eventually you will get it down. Your brake wont have improved, but because you've got used to doing the same line your body will at some point make the difference between sticking it and slipping it. See where I'm coming from? t However, thats not too say a good brake isnt important. Quote Link to comment Share on other sites More sharing options...
