Mod Man Leo Posted March 8, 2007 Report Share Posted March 8, 2007 ok so i have a t-comp and ive just set up my hs33 it runs like a beast! but it runs abit too like a beast and it flexxes the frame quite alot, so after a certen amout of lever pullage the frame starts to run away from the rim.i am not running a booster atm but i am going to get one, will this help?i was thinking of getting tensile booster -- i heard there one of the stiffest.can you recomend a booster for the job ,about £25? Cheers Leo Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 8, 2007 Report Share Posted March 8, 2007 Yeah, you just need a booster. I'd go for Heatsink, they're really beefy and stiff but still very light. Quote Link to comment Share on other sites More sharing options...
*BOOTHY* Posted March 8, 2007 Report Share Posted March 8, 2007 Onza carbon 4 bolt booster *** Quote Link to comment Share on other sites More sharing options...
adam trials Posted March 8, 2007 Report Share Posted March 8, 2007 Just about any boster will do i was running the one that maggies come with and my frame didnt flex again.Adam. Quote Link to comment Share on other sites More sharing options...
ruption0 Posted March 8, 2007 Report Share Posted March 8, 2007 booster will do you some good i currently have the tensile one on my onza t mag works a treat Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted March 8, 2007 Report Share Posted March 8, 2007 Onza carbon 4 bolt booster ***Thats what i've got, does the job for me. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2007 Report Share Posted March 8, 2007 All you need is a big beast of a booster as this will take the brake power rather than the frame. it should also make ur brake work a bit better and make it more reactive. just remember not to go cheap and get a magura one as they dont stop the frame flexing because i got them with mine and they are seriously pants. hope ive helped Quote Link to comment Share on other sites More sharing options...
montyrider Posted March 8, 2007 Report Share Posted March 8, 2007 heatsink or the echo team are the strongest in my opinion i had the same problem, and fixed it with the echo but the heatsink ones have a lot of egg heads who make them Quote Link to comment Share on other sites More sharing options...
Onza-rider Posted March 8, 2007 Report Share Posted March 8, 2007 RB booster they look class Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted March 8, 2007 Report Share Posted March 8, 2007 Echo 4 bolt , cheap and does what its made for Quote Link to comment Share on other sites More sharing options...
t.w Posted March 8, 2007 Report Share Posted March 8, 2007 Echo 4 bolt , cheap and does what its made for i agree echo is very very stiff anf does his job very well. Quote Link to comment Share on other sites More sharing options...
aener Posted March 8, 2007 Report Share Posted March 8, 2007 +1Echo 4-bolt.Cheaper than the rest (or a good portion of them anyway) - and does the job very well.Peeerfic Quote Link to comment Share on other sites More sharing options...
monty221pr Posted March 8, 2007 Report Share Posted March 8, 2007 my brother had a t-comp and it snapped rite near the brakes and i have seen alot of pictures were people have snapped t-comps their so i would be carefull. Quote Link to comment Share on other sites More sharing options...
Sucram Posted March 8, 2007 Report Share Posted March 8, 2007 Ive got the GU booster and its a big beefy thing works very well and looks mint. Quote Link to comment Share on other sites More sharing options...
spmcfadden Posted March 8, 2007 Report Share Posted March 8, 2007 With the brake pulled hard the rim won't move anywhere so most of the force will be transferred to the mounting bolts causing the frame to flex, the booster holds the two brake cylinders together so the force goes onto the rim giving you high braking power. So any booster will help! Quote Link to comment Share on other sites More sharing options...
Token Posted March 8, 2007 Report Share Posted March 8, 2007 Just get any 4 bolt booster.2 bolt ones aren't that great to be honest. Quote Link to comment Share on other sites More sharing options...
moto_psycho Posted March 9, 2007 Report Share Posted March 9, 2007 I ran mine without a booster for a while, when the TPA was eventually adjusted all the way in with completely unworn pads I decided to invest in a tensile booster. Jesus Christ the difference was amazing! Wouldn't even think of running without one! Quote Link to comment Share on other sites More sharing options...
