(chief) Posted March 6, 2007 Report Share Posted March 6, 2007 (edited) Hi i am wanting to know what gear ration i should run on a zona zenith with try all cranks 165mm length i was thing 18:17 but am not sure. cheers(Y)also what size bb do i need to run on one could i get away with a 118 mm axle???chris Edited March 6, 2007 by (chief) Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted March 6, 2007 Report Share Posted March 6, 2007 18:17 is probably a bit low unless you like it really spinny18:16 or perhaps 18:15 would be a bit more regular, giving ratios of 1.125 and 1.2 respectivelyPersomally I'd go for 18:15 given the option of the two Quote Link to comment Share on other sites More sharing options...
Joe Sheehan! Posted March 6, 2007 Report Share Posted March 6, 2007 My freind has a Toxsin One, and he has a 16T Middleburn crank.What cog should he run on the rear? (Singlespeed)Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Waddy Posted March 6, 2007 Report Share Posted March 6, 2007 18:17 is probably a bit low unless you like it really spinny18:16 or perhaps 18:15 would be a bit more regular, giving ratios of 1.125 and 1.2 respectivelyPersomally I'd go for 18:15 given the option of the twoyer 18:16 and 18:15 are moe common, but he is running short cranks, so maybe a ligher gear to even it out abit,try 18:17 chris, and if that is too easy run 18:16 Quote Link to comment Share on other sites More sharing options...
JoNnY__Mc Posted March 6, 2007 Report Share Posted March 6, 2007 I would use 18 : 16, I used to use that on my saracen mad with 165 cranks... I now use 18 : 15 with 175 cranks on my zenith, feels better for me because I can put more power down when I want to.You'll need a long bb, maybe 127 ish... I run an skf ... on my zenith frame I had to get my bottom bracket shell faced *-) you might want to look into that. Quote Link to comment Share on other sites More sharing options...
abtrials Posted March 7, 2007 Report Share Posted March 7, 2007 i am running 18/17 on mine with 170 cranks and it is fine i tryed 18/16 for a bit but gap,s and bumps were harder oh yea also by running 18/17 with a kmc cool chain you dont need any tensioner Quote Link to comment Share on other sites More sharing options...
scousertrials Posted March 7, 2007 Report Share Posted March 7, 2007 what gear ration do you guys think is best for a monty urban with a 26" rear wheel, i have a 22t chain ring on the crank and would like to know if i should use a 19 or 18 toothed sprocket on the hub end. what ratio do the big guys use ( excellent riders who ride stock). kind regards all Quote Link to comment Share on other sites More sharing options...
padarik Posted March 7, 2007 Report Share Posted March 7, 2007 16 14 im runnin perfect Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted March 7, 2007 Report Share Posted March 7, 2007 18;16 is the sex for me, on 170 mm tensiles, try out 18;17, you can always change it matt Quote Link to comment Share on other sites More sharing options...
SomeoneNew Posted March 7, 2007 Report Share Posted March 7, 2007 22-19 ***, thats what I run on my zenith (and ran on my mony urban) Feels good to me so i go with something with a similar ratio to that! Quote Link to comment Share on other sites More sharing options...
(chief) Posted March 7, 2007 Author Report Share Posted March 7, 2007 Cheers i have decided to go with 18:17 hope its fine but cheap to get a new cog just trial and error really.chris Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted March 7, 2007 Report Share Posted March 7, 2007 Nooooo! Too low!Unless you are a fan of really spinny gears I wouldn't recommend anything lower than 18:16 Quote Link to comment Share on other sites More sharing options...
GyTrials Posted March 7, 2007 Report Share Posted March 7, 2007 im currently using 20-16 and it seems fine for me used the same gear ratio on all trials bikes including my zenith Quote Link to comment Share on other sites More sharing options...
