jack219 Posted March 6, 2007 Report Share Posted March 6, 2007 I'm having trouble setting up my brakes because everytime i set them up they rub against my rim . So i then have to adjust the tpa which makes the levers touch the bars and it doesnt feel nice!!Does anybody have any tips which will help me!!JACK!! Quote Link to comment Share on other sites More sharing options...
Phil H Posted March 6, 2007 Report Share Posted March 6, 2007 I'm having trouble setting up my brakes because everytime i set them up they rub against my rim . So i then have to adjust the tpa which makes the levers touch the bars and it doesnt feel nice!!Does anybody have any tips which will help me!!JACK!!Im presuming you got maggy by the TPA.Basically could be a number of problems. I dont see how they can be rubbing if you just set them up straight, do them up tight and put TPA on full. Should give you a nice feel.If the problem is that one piston isnt moving back and so rubs, this is abit of an annoying one. What is the precise problem?Consider getting a re bleed?Phil Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted March 6, 2007 Report Share Posted March 6, 2007 Im presuming you got maggy by the TPA.Basically could be a number of problems. I dont see how they can be rubbing if you just set them up straight, do them up tight and put TPA on full. Should give you a nice feel.If the problem is that one piston isnt moving back and so rubs, this is abit of an annoying one. What is the precise problem?Consider getting a re bleed?Philbuckle in your wheel? Quote Link to comment Share on other sites More sharing options...
Dr Dig Posted March 6, 2007 Report Share Posted March 6, 2007 Adjust the tpa fully out before u put the pads in. Use a credit card between your rims and pads to stop rubing. It works for me Quote Link to comment Share on other sites More sharing options...
Netherking Posted March 6, 2007 Report Share Posted March 6, 2007 also clean around the top of the pistons, mine always get gummed up! makes one of them lazyWD 40 them after Quote Link to comment Share on other sites More sharing options...
