I Have A Wobble..
Barbra
Well my bike has been skipping for a while, thought it was the freewheel, but its definately not that because i now have an Eno. The bottom bracket is also fine, i had a new 'un not long ago. So either the rear wheel is fudged or i've done something wrong.
The freewheel seems to not spin in a straight line, it goes ape shit, it turns in sort of an S type shape, but obviously less dramatic.
Any help appreciated.
All freewheels wobble.
Or from my experience they do :)
the freewheel is second hand, its been serviced runs a beast. So its not that, it might be worth me buying a new bb, not that dear for a square taper one. But i don't think its that because its skipped through 3 bbs already, same wheel 3 different freewheels and 2 different chains. The only thing that i can think of is its the wheel. But it doesn't make sense.
The wheel will have no bearing on how 'straight' the freewheel spins. It sounds like the threads on the crank aren't perfectly matched to the freewheel, this is perfectly normal - a little tolerance on both parts can easily add up to make it look bad. For example, my freewheel/chain appears to waver around 2mm but it causes no problems whatsoever.
Cheers
Adam
