Hope Trouble
!Billy_BOY!
Hey guys.
right for some time now Ive had this problem with my front disk (hope mono trial).
what it is is that when i pull in the brake leaver and then just let go it don't go back to normal position it just pings right out of place, so for several months Ive had it taped up to stop the "pinging" :mellow: .
but I'm getting sick of it now and i have some money so its time to sort it, so does any one no what it is or has any one had this problem and what do i need to fix it ?
is it this ? >>LINK
help appreciated!
thanks Billy
Which bit is 'pinging' out of place.
If it is that bit that you put a link up to it sounds like the piston bit in your lever need replacing/looking at.
If it has a slow return when you release the lever it may be that bit that needs replacing or simply just taking out, looking at and rebuilding.
Like t.w said take it to a bike shop and they'll sort it for you
Frooty
aup mate. i had this problem when i had my hope brakes. all i did was buy this and it solved all my problems. i reccommend you read the instructions before trying to attempt it yourself other wise it could be disaster as i found out.
hope i have helped.
cheers lou.
