Synergy Posted March 4, 2007 Report Share Posted March 4, 2007 http://www.tartybikes.co.uk/product.php?id=2155http://www.tartybikes.co.uk/product.php?id=2156basically im planning getting a new set of rims at the end of next month,i understand double wall is stronger than single wall, however im unsure on the Un-eyeletted construction will that make it weaker than your echo or koxx rims?also i like the look of the front rim because the drill holes are different unfortunately they are 28 hole so wondering is there any other rim out there with a design like that? Quote Link to comment Share on other sites More sharing options...
David20 Posted March 4, 2007 Report Share Posted March 4, 2007 (edited) I hope your not planning on getting white rims. Edited March 4, 2007 by David20 Quote Link to comment Share on other sites More sharing options...
Synergy Posted March 4, 2007 Author Report Share Posted March 4, 2007 I hope your not planning on getting white rims.thanks for your help muppet Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 4, 2007 Report Share Posted March 4, 2007 (edited) If you desperately want square holes, get a normal front rim and make them yourself using a file.Echo / Koxx rims are also un-eyelettededit: you could also check out Abant rims. They've been around longer than the new Ti rims which suggests that they originate from a different rim, possibly a 32h one. Edited March 4, 2007 by Inur Quote Link to comment Share on other sites More sharing options...
Synergy Posted March 4, 2007 Author Report Share Posted March 4, 2007 If you desperately want square holes, get a normal front rim and make them yourself using a file.Echo / Koxx rims are also un-eyelettededit: you could also check out Abant rims. They've been around longer than the new Ti rims which suggests that they originate from a different rim, possibly a 32h one.are the abant rims strong? also where can i get them from? Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted March 4, 2007 Report Share Posted March 4, 2007 my front one is awesome it hasn't buckled yet and i've propper hit it loads Quote Link to comment Share on other sites More sharing options...
Dr Dig Posted March 4, 2007 Report Share Posted March 4, 2007 my front one is awesome it hasn't buckled yet and i've propper hit it loadsTelling him what front wheel you ride might be helpful ! Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 4, 2007 Report Share Posted March 4, 2007 AbantIt seems that the 2007 rims are based on Monty Ti rims which means you can't get front rims in 32 hole. Might be an idea to email them, they might have some old rims in stock but i'm not sure if those were 32 hole.email is josep@abant.net Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted March 4, 2007 Report Share Posted March 4, 2007 Telling him what front wheel you ride might be helpful !quite obviously a monty ti Quote Link to comment Share on other sites More sharing options...
