Sponge
Just drill it out.
Even if you do cock up the threads a little then you can just get it helicoiled. :) or just use the nut on the other side to hold it. Thats what I did on my old levelboss. The threads were compleatly gone, so I just used the nut to hold it in place, works fine.
Seeing as there's a nut there, two possibilities:
The frame is tapped like normal and the nut is there to lock the bolt in place. In which case you need to release the nut before the bolt will move.
The frame has been drilled out in the past and the nut is the only fastener. In which case it should repond to hacking the head off the bolt and knocking the whole lot through.
In the second case, drill it out. Center pop the remains of the bolt, drill to tapping size then run a taper tap through. I wouldnt exactly call that the lazy option :turned:
If you snapped an allen key trying to get it out, putting more force on will probably only serve to tear the threads. So drill it.
Drill the head of the bolt off so the bash can come off. Them because you have released the tension of the bolt, you will be able to just undo the bit of bolt that is sticking out of the frame by hand. Have to do it all the time at work because of heavy handed bastards who cant use allen keys
Another option you could try is what's called an "EEZIOUT". Basically you drill a small hole into the bolt (2 or 3 mm) and screw the eeziout in. It has a left handed spiral on it which draws it into the hole as you try to undo the bolt. The harder you try and undo it the tighter it gets in the hole meaning the bolt will eventually come out.
Only problem is, these are not very common so you would need to find an engineering shop or something similar to help you out. I can get hold of these so if all else fails, PM me and i'll send you one to try.
can get them all over the place.
There you go
Just drill it out.
You could be this, but unfortunately the bolts used for bashplates are high tensile steel, and so are drill bits.
Now drill bits are harder, but I still shattered one when trying to drill the snapped end out of my frame.
I would grind the rest of the bash off with an angle grinder, then clamp some of the biggest mole grips you can gets your hands on round the rest of the bolt (might be an idea to grind two flats on the countersunk head first) and wiggle it back and forth until it frees up.
Or just run with no bash, as the newer pythons do.
Edited by KuelMuel
