Spokes For Rear Disc Wheel
Greetings
OK people, got one last question concerning 26" rear disc setups.
Probably the biggest problem with 26" rear disc wheels is the wheel flex?
I need some info about what spokes to use and how many crosses to go for, and maybe any tips that might help make the wheel as strong as possible.
It'll be built by my LBS but I don't trust them completely so I will want to give them as much useful information as possible before they get down to it.
The wheel will be built on a King singlespeed which is probably a good start.
Oh, and I'd really like to know what Bigman used, for if his wheel lasted, mine will.
My tips would be:
Make sure the rims eyeletted.
More tension than usual, but not looaaads
36h!
4X!
And make sure you get the spokes the right way around on the disc side, asin the ones that are going to take the braking force should be on the outside of the flange on the disc side.
Also as its a disc wheel, worry more about even tension than it being perfectly strait.
Thats about all I can think of right now.
Oh yeah, and DT strait guage spokes if you want ultimate stiffness and strength. (Y)
Cheers, so I should point out to the shop that the braking force will be working the opposite way to a normal wheel?
And another thing, DT plain gauge spokes are called Champions, I heard/read that Alpines are way stronger.
Do you mean to say that Alpines won't make a stronger wheel for this specific purpose?
I'm not sure of the names of the DT range, are the alpines the Double butted ones? if so they should be slightly flexyer than the staight guage ones, but not nesisarily weaker, or stonger. If alpine are a different make then I've never heard of them. So can't really comment.
And yeah, that is what I was meaning about the spoke directions, just mention it to them.
Right, basically, a double butted spoke flexes more in the middle, so the fatigue is better distributed over a larger volume of spoke, so they last longer. A non butted spoke has a greater absolute strength, however normally snap first because the flex is usually contained in a small volume of spoke, typically near the head of the spoke, which experiences greatest fatigue, so snaps first...
I've always used butted spokes so I can't compare the two, but the above is what I've been told and to me it makes sense.
I was running a 36h CK discotech with a 36h koxx rim, 4x build using sapin DB spokes, built by tart, they wheel held out VERY well, i had the same build up until a few weeks ago when i demolished the koxx rim on a gap in portsmouth.
Adam
Thanks people. So to sum up, double butted spokes will give a longer lasting but less stiff wheel, whereas plain gauge ones will give a very stiff and strong wheel for a short period of time? I had a rear disc a while ago but that was 20" so it's kind of different, only problem was that after a few months most of the spokes snapped near the head.
I think I'll go for the plain gauge ones and see how things go. Don't mind a new wheelbuild every now and then, it's dead cheap including spokes anyway.
Pretty much :)
As the Big Man has said though, 4x 36h with butted spokes will be just great, and you won't have to worry about snapping spokes.
Adam
