Magura Problem
is there any other way to regain pressure in my magura other than bleeding. Yestreday the hose came slighty loose and a tiny bit of oil leaked out ( and I mean like a drip) but obviously the pressure has now changed. The brake still grips perfectly but I want to know if I can get some more pressure into it somehow. I have moved the pads right in and adjusted the TPA to its maximum but the lever is still nearly touching the grip when squeezed. Is there anything I can do, no sarcastic comments please. Thanks
