Rear Disk Help
the_ferret
hiya folks...
basically as it says i just need to know what disk to go for on the rear of a monty... im 12 and half stone so needs to be strong and my current avid just isnt up to the job at all! the disk bites real nice but just seems to lack power when i need it. so id appreciate any opinons on a new one as i havent got a clue been off the scene for a year! or if anyone has tips to sort the one im using now
thanks oggy
yh if you want tones of problems then by all means buy a mono trial but if u want reliabilty then buy a hayes mx2 cable brake or a avid bb7 2005 and then you will know true power .
I don't have any problems with mine. Worked straight out of the box.
Just set the brake up correctly in the first place and don't re bleed it every week and you'll never have a problem.
Avids aren't everything, just easier to repair and setup if you don't understand disc brakes that well.
Rob
