Is A King Hub Really Worth It?
NVWOCI WVS
well, me dan, alex and soon pip all ride with them, ever skipped on you or us for tht matter? no. the only one ive ever seen skip was richs when i raped his front wheel, whereas ive seen countless kings skip...
so i feel you calling the hubs failure isnt really justified
Ash, i never siad kings don't skip, but i do indeed fell that Hope have failed with the objective here, they set out to design a strong TRIALS SPECIFIC hub. Compared to the king they are a relatively new hub, yet seem to have had as much publicity with problems in trials from what i have personally seen.
They had problem with the hubshell, granted that was probably down to excesive spoke tension, and has been sorted, but was a problem none the less, and king hubshells are damaged as there not designed with such extreme use in mind, the Hope WAS! Richs hub seems to have been the worsed skip i have witnessed, and i have explained in a previous post how the king and hope skips differ, and why. Freds has skipped, ive ridden it and its skipped slightly on me, as Chris says mike's from salisbury is bad, i have seen it skip many times, and ash don't try and say none of your guys hubs have never skipped on you! they have! Maybe not as extreme as a king, but they have!
From what i can see, i have to say i may not be right, i dont have sales figures vs returns, but the ProIIt seems to have had as many problems in trials use as the Hope XC, if not more. This to me constitutes a failure in meting the design criteria! Remember king never set out to design a trials specific hub!
Edited by nmt_oli
Been reading this thread for a number of days.
Become clear to me whatever hub you buy out of the two there is always going to be people who have suffered at the hands of the hub. No product is perfect.
I'm not a good person to comment on this as I run a hope xc (which is trustworthy). However if you've got the money King definetly has respect in the trials community which says something about its quality. (like middleburns for example)
The above would push me in the direction of King but my mate ran pro 2's succesfully on his downhill bike which might say something.
Personally I wouldn't get a king as I couldn't really justify the money with myself. Just a couple of my thoughts.
Phil
Very limited choice with gearing though!
Yeah, it sucks, sp someone bring out your trials freewheels in some other sizes than 18t! Also if you ever want to ride comps that need 6 gears its new hub time. Also it's heavyer.
Saying that I run this setup with a DMR revolver and an ACS freewheel (only one I could find in 16t although aparently trials-man can get/do have some 16t and 17t Try-alls) and its never skipped on me, on the rear ACS freewheels are alot better, they never come loose and seem like alot lees maintainence is needed. It's not just me either, Ben more was running this for ages (only with an echo screw-on hub) and I never heard of it skipping, he eventualy got an ENO for christmas just for the quality and noise. Oh yeah, you can get enos in 16t and 17t, but only in the 36 engagement version.
DMR Relover with an ENO or similar.
Wider flange spacing = stronger wheel
choice of number of contacts if you choose a different freewheel
combo cheaper than both CK and hope
not everyone in the world has them!
My perfect setup except the choice of teeth on freewheels is way to limited
Praying for a 15 or 14 tooth freewheel in the future :bow:
If anyone does get the Pro2, then get the 2nd generation models as they are claimed to be stronger build. number of riders have snapped the 1st generation hub shell. one rider snapped his 2nd Pro2 hub clean after pedalling away from a trackstand (at london ride). Very weird to see a snapped hub shell that is machined from a solid billet of alu.
i had a fair bit of trouble with my king when i first got it.. skipped lots, kept coming loose etc. but got new drive and driven rings on warranty off aspire, and a new axle because i snapped the end of the old one.
i then took it fully apart, cleaned and lubed, and it's been good since then. it's a really nice hub.
i rode acs front freewheel for a year or two before i got the king, and had no trouble with it. skipped once i think, and was perfect. didn't break either, just had to let go of it as i got my king.
they're good hubs if you can use tools..
unless your a comp head and probably even then the majority of people in my opinion run the same gear for general trials riding...
i understand that this will limit you when running a freewheel on 26 for comps...
i think alot of people over look it
keep it real B)
keep it real B)
your dmr/eno combo feel really good dude, but yeah the limted choice of gearing is probably the worse thing, I don't think I could a freewheel equivalent of the 20-15 on mine...
get some straight cranks so you can fit a 22T ring and get back to work! hehehe
its still underated though.. at least if you freewheel packs in then its not a case of sending your wheel and you don't need expensive tools like you need for a king...
my cranks are straight, its just my bb that isn't ... :shifty:
I have to agree with Prawny here, i have had a rear CK classic since june/july 2003 and it gave me a few probems to start, due to pete wright killing the drive rings and spring, since having new drive rings and springs fitted in autom 2003 it has given me no troubles.
I have seen many pro 2's skip and i don't think i could trust one.
Adam
doesn't that show something else though? like a metal failure compared to actual strength (this makes sence in my head) thats a faulty batch but i've seen theses hubs getting beasted no problems i run a eno so i don't have much experienec in freehubs. but i don't see how a king justifies the price tag.
Don't you need a really expensive tool to crack open your king? compared to a lockring tool and probably one or to other things you need to open up a "normal" freehub?
Edited by ogre
