monty kid Posted February 25, 2007 Report Share Posted February 25, 2007 HiIm buying a new rear rim for my monty 221pr but dont no what one to get but its got to be available in red and disc mounted also. Dont mind how much.cheers Quote Link to comment Share on other sites More sharing options...
lankyri Posted February 25, 2007 Report Share Posted February 25, 2007 for the front i'd say hope xc and for the rear go for a chris king if you got the money although the viz hubs look cool Quote Link to comment Share on other sites More sharing options...
samo Posted February 26, 2007 Report Share Posted February 26, 2007 i think you can get a king hub with disk mounts on Quote Link to comment Share on other sites More sharing options...
max-t Posted February 26, 2007 Report Share Posted February 26, 2007 The chris king bmx hubs dont come in disc mount. Quote Link to comment Share on other sites More sharing options...
trialsboy_06 Posted February 26, 2007 Report Share Posted February 26, 2007 Hi i have got a viz hub and it run really good. With the viz hub they are quite cheap. they are just as good as the other but they are cheaper. Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 26, 2007 Report Share Posted February 26, 2007 (edited) A chris king BMX disc hub won't work with 110mm hub spacing which the PR has unless you do an adaptor bodge or machine down the brake and hub which I doubt you would like to do. The problem with this hub is that the disc mount is too close to the frame (after all the disc shell isn't designed to be used in bmx hubs) leaving no space for the caliper. With a 116mm spaced frame like any other apart from Monty, you can put all the tensioners on the non drive side and align the rotor correctly.Besides, does it have to be red? You'd have a huge choice of hubs otherwise, Echo make some, Monty make the 221Pr and Ti hubs in disc form and I'm pretty sure Viz do as well seeing as they copied Monty hubs (or vice versa).Um what about profile disc hubs? Edited February 26, 2007 by Inur Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted February 26, 2007 Report Share Posted February 26, 2007 1 wordKing Quote Link to comment Share on other sites More sharing options...
t.w Posted February 26, 2007 Report Share Posted February 26, 2007 (edited) A chris king BMX disc hub won't work with 110mm hub spacing which the PR has unless you do an adaptor bodge or machine down the brake and hub which I doubt you would like to do. The problem with this hub is that the disc mount is too close to the frame (after all the disc shell isn't designed to be used in bmx hubs) leaving no space for the caliper. With a 116mm spaced frame like any other apart from Monty, you can put all the tensioners on the non drive side and align the rotor correctly.Besides, does it have to be red? You'd have a huge choice of hubs otherwise, Echo make some, Monty make the 221Pr and Ti hubs in disc form and I'm pretty sure Viz do as well seeing as they copied Monty hubs (or vice versa).Um what about profile disc hubs?1 wordKingread the above Edited February 26, 2007 by t.w Quote Link to comment Share on other sites More sharing options...
