Phill_Monks Posted February 24, 2007 Report Share Posted February 24, 2007 what dose everyone clean there rear king hubs out with, iv got some different lube's but which do you use ?????phill Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted February 24, 2007 Report Share Posted February 24, 2007 Finishline wet xc lube. I used to dab it round the drive ring so there wasn't too much lube and it always worked well . Alot of people use wd40/gt85 Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted February 24, 2007 Report Share Posted February 24, 2007 Wd40, then run it dry. MMMmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm lol.Mat Quote Link to comment Share on other sites More sharing options...
Waddy Posted February 24, 2007 Report Share Posted February 24, 2007 Wd40, then run it dry. MMMmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm lol.Matyep, wd40, and run it next to dry, thats what i did and it never skipped Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted February 24, 2007 Report Share Posted February 24, 2007 yep, wd40, and run it next to dry, thats what i did and it never skipped Unless you ride natural alot then i suggest you put some lubey of a sort in there, even if its just finishline Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 24, 2007 Report Share Posted February 24, 2007 not sure running a mechanism where there is strong friction between it's elements is a good idea.I run mine on a small amount of Castrol GTX. Didn't have anything else, it works rather well though. Quote Link to comment Share on other sites More sharing options...
max-t Posted February 26, 2007 Report Share Posted February 26, 2007 Anything thin based like GT45 , wd40 , wet lube etc... Quote Link to comment Share on other sites More sharing options...
